TBS8922 and Windows 10 not working
Postby d0ORk » Wed Mar 27, 2019 9:11 pm
Hi there, I used my 8922 with Win7 64bit and DVBViewer and it worked fine.
I bought a new SSD and made a clean Windows10 install.
I installed the tbs8922-win10-driver_v1.0.1.6 from your homepage.
Device Manager shows everything ok.
But I cant find any stations with DVBViewer and/or ProgDVB.
Can only be a driver problem, because it works when I plugin the other SSD with Win7.
Any help here?
d0ORk
Re: TBS8922 and Windows 10 not working
Postby konradpaluszek » Tue Apr 02, 2019 1:40 pm
Hello. I have the same problem. Please help
konradpaluszek
Postby steven » Thu Apr 04, 2019 9:25 am
hi
can you take one picture about the device manage page , is the tbs8922 capture device installed ?
