All Flows cut off if we stop a stream on vlc.
Postby AsiNice » Thu Mar 21, 2019 4:09 pm
We have just made an acquisition of the TBS2603 case for a customer.
After browsing, I have some trouble with the case.
I need to be able to stream with 14/15 people without HD streams (Text View only) but latency is visible between all devices. Moreover, as soon as I cut a stream on VLC, all the other flows are cut off.
The setting is as follows:
H264 / Baseline Profile
Frame Rate: 25
Bitrate Control: CBR
Key Interval: 30
Bitrate: 500
Http: Enable
Audio Bitrate: 48000
Firmware 1.1.87
Hoping that you can bring me a solution.
Best Regards
AsiNice
Re: All Flows cut off if we stop a stream on vlc.
Postby daowei » Thu Mar 21, 2019 5:07 pm
AsiNice Wrote:Hello,
Frame Rate: 25
Key Interval: 30
Bitrate: 500
Http: Enable
Firmware 1.1.87
Best Regards
We limited the connection, to many connections will bring another problem. Becasue this is based on an ARM platform and a heandend device, can't handle so many requests, the purpose is to capture the source.
You can prepare another distribute software i think, like Xtream-codes, it supports more users:
Encoder----ip stream---upload to Xtream-codes----distribute to users
Now can try reduce the number of the connections. And maybe "key interval" set to "25/50" will be better; and also the bitrate,
maybe you can set to a higher, too low maybe the quality will be poor.
Users browsing this forum: No registered users and 22 guests
