Is this device work at all?
Postby Barbrix » Wed Feb 27, 2019 8:37 pm
I try linux and windows no luck
Barbrix
Re: Is this device work at all?
Postby VictorLS » Fri Mar 01, 2019 4:48 am
What SAT program(s) with?
Have you seen lock (green LED) although once?
Have you run TBS5520se_ChangeMode_Tool.exe - may be you try to lock SAT but TBS 5520SE isn't in DVB-S mode ;)
Russian Crimea, 1200x1100 103E-30W Ku,Ku cir, C cir; OMICOM S2 PCI & TBS 5520SE
VictorLS
Postby steven » Fri Mar 01, 2019 9:50 am
Barbrix Wrote:I try linux and windows no luck
please provide more detail information to help us find where the problem is
Postby Barbrix » Fri Mar 01, 2019 6:59 pm
Im from the usa so i need atsc.. is there any tutorial on how to work with raspberry pi with tvheadend.. i pay somebody to do it for me he actually install the driver but it wont get any signal or anything it says fail...
Barbrix
Postby steven » Thu Mar 07, 2019 4:17 pm
for 5520se it do not support ATSC , for ATSC we only have TBS6704 PCI-E card now and for ARM platform we have not tested yet
not sure it will work
KindRegards
Postby VictorLS » Sun Mar 10, 2019 3:26 am
Thanks for reply.
Btw ATSC present in TBS5520se_ChangeMode_Tool.exe ;)
VictorLS
Postby steven » Wed Mar 13, 2019 10:05 am
Hi VictorLS
Thanks for your update ,when you choose ATSC it should give you message do not support : )
Postby VictorLS » Sat Mar 16, 2019 9:54 pm
Yes, it's so!!!
I just didn't try before ;)
Best regards.
VictorLS
