How install driver TBS6618 on Ubuntu 14.0.4
Postby mojbuk » Tue Feb 19, 2019 2:52 pm
Best regards.
I try to install a driver. I've tried manual downloading, the installation process is over, but there is nothing when I call the command
dmesg | grep fronted
When try with this topic: https://www.tbsdtv.com/forum/viewtopic.php?f=86&t=25046&p=54217#p54217
have error with kernel, need latest kernel 4.19... but cant install on ubuntu 14.
Every help would come well thanks.
mojbuk
Re: How install driver TBS6618 on Ubuntu 14.0.4
Postby steven » Thu Feb 21, 2019 6:09 pm
for 6618 please use this driver it support the kernel under 4.10
#sudo rm -rf /lib/modules/`uname -r`/kernel/drivers/media/
1.wget http://www.tbsiptv.com/download/common/tbs-linux-drivers_v170330.zip
2.unzip tbs-linux-drivers_v170330.zip
3. tar jxvf linux-tbs-drivers.tar.bz2
4. cd linux-tbs-drivers
5. ./v4l/tbs-x86_64.sh
6. make -j4
7.make install
8.restart
Postby mojbuk » Fri Feb 22, 2019 4:18 am
steven Wrote:for 6618 please use this driver it support the kernel under 4.10
6. make -j4
7.make install
8.restart
Thank you. Working OK.
mojbuk
