TBS6903-X drivers
TBS6903-X drivers
Postby beavs2112 » Tue Jan 22, 2019 2:59 pm
@steven Hello. I purchased card this week. When are TBS releasing WIN10-64 drivers. Currently get BSOD using 6903 driver. Or can I use 6904/9-X drivers? Please ask card devs to make this issue a priority. (Hint perhaps crazycat can help!).
Two 3.0M Prime Focus Dish - TBS 6903X,6903,6522 - Intel i7 4770K - 16GB RAM - GTX 1080 - Win10-64
beavs2112
Re: TBS6903-X drivers
Postby steven » Mon Jan 28, 2019 9:39 am
For 6903x windows 10 driver you can use this :
http://www.tbsiptv.com/download/tbs6903 ... _win10.zip
do you have tested ? it have problem ?
Postby beavs2112 » Tue Mar 26, 2019 12:44 pm
Issue resolved with BSOD when using latest drivers.
beavs2112
Postby steven » Wed Mar 27, 2019 4:35 pm
You mean with latest driver you have BSOD ? do you have tested at another PC is it the same ?
Postby beavs2112 » Fri Mar 29, 2019 9:32 am
No steven I mean all is ok with latest driver. my problem is fixed.
beavs2112
Postby s0nnenschein » Thu Jun 27, 2019 12:39 am
He is right. If you want to install the 6903 driver you will get the BSOD. It's hard to understand why a complete different hardware has the same article number, only an additional X is the difference.
s0nnenschein
Postby satesco » Tue Jul 09, 2019 12:22 am
s0nnenschein Wrote:He is right. If you want to install the 6903 driver you will get the BSOD. It's hard to understand why a complete different hardware has the same article number, only an additional X is the difference.
Each card has a different hardware,even small,that distinguishes it from another,but the most important being the chip/demod.Depending on it the other components are built, with more or less identical functions and other features.
TBS chose to make series of models depending on usage and standards.For example,the 6XXX model is for TV Tuner PCIe,the 5XXX model is USB -supported,the 8XXX model is for IPTV server, etc,etc.Each model is updated according to new dvbs technologies that appear on the market,and TBS does nothing but improve each model to provide something new to those interested in new technologies of reception,capture and streaming.
For example,the 6903 -X model is equipped with the STid135 chip,compared to,say,tbs6903,which is based on the STV091X chip. The first one knows how to work with the S2X extension,while the last one does not have this possibility.
Here's briefly why TBS uses numbers and letters for its products.I hope I wasn't wrong in this brief presentation.
satesco
Postby Deeman » Wed Jul 24, 2019 6:11 pm
I was given to investigate the possibilities of the TBS6903-x.
I have Windows 7 and latest drivers from https://www.tbsdtv.com/download/index.html
The output stream from this card not correctly.
This is a TS-stream of DATA transponder with HDLC protocol. I record the signal at TSRecorder, CrazyScan and I/Q Monitor.
At all programs the same result. (Look at 11-12 bytes).
The result from TBS6522 is correct.
Deeman
Postby enb141 » Wed Sep 18, 2019 6:40 am
Any ETA about a new driver that fixes the wake from sleep issue with the TBS6903-X on windows 10.
enb141
Postby Babadem » Mon Jul 27, 2020 7:38 am
There is need for a new release of drivers and softwares to improve Blindscan amongst other issues.
Babadem
