TBS6909 proxmox 5 VM/LXC
Postby gusto » Fri Dec 28, 2018 6:09 pm
Hi all
Sorry my English is very poor
HW
MainBoard
CPU
DVB-S2 card
OS Proxmox 5.3-5 - kernel 4.15.18-9
Identification devices in proxmox (host)
I have two DVB-S2 cards
lspci
07:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
08:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
I installed driver for TBS6909 by http://www.tbsiptv.com/download/tbs6909 ... _guide.pdf
Everything went well.
If I write in terminals.
dmesg | grep frontend
I do not see any adapter.
/dev/dvb/ is empty.
Then I found that I need to secure boot disable viewtopic.php?f=176&t=9980
When I set up secureboot disable, after reboot is always secure boot enable (hmm).
I tryied
sudo apt install mokutil
sudo mokutil --disable-validation
and after entering and confirming password
I see
Failed to request new SB state
Will DVB card work on my HW at all?
Will DVB card work in VM or LXC ?
thank you
gusto
Re: TBS6909 proxmox 5 VM/LXC
Postby steven » Sat Dec 29, 2018 10:31 am
#wget http://www.tbsdtv.com/download/document/linux/media_build-2018-1019.tar.bz2
#tar jxvf media_build-2018-1019.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby gusto » Sat Dec 29, 2018 3:59 pm
Hi steven
I tried it, but nothing changed after the reboot
thx
gusto
Postby steven » Wed Jan 02, 2019 3:11 pm
You test in VM ? usually we do not recommend use the DVB tunner card under VM. if you are using a normal PC
Please set a SSH remtoe we will remote install the driver for you you can send the SSH detail information to our support@tbsdtv.com
Postby gusto » Wed Jan 02, 2019 8:54 pm
Hi steven
I want to use a DVB card either in VM or LXC. First, The DVB card must be visible to the host (proxmox (debian)).
I do not have a normal PC, I only have a proxmox hypervisor. I want to build a DVB server on VM or LXC (e.g. https://forum.proxmox.com/threads/lxc-d ... ugh.24951/ )
May I send you SSH detail information for VM ?
Should i install debian or ubuntu ?
thx
gusto
Postby steven » Thu Jan 03, 2019 10:11 am
Sorry that we have not tested DVB tuner card under VM/LXC you can send SSH PM message to me
i can have a try
Postby gusto » Sun Jan 13, 2019 8:43 pm
Solution for Proxmox 5 (Similarly debian)
Find kernel version
uname -r
In my case
4.15.18-9-pve
apt-cache search pve-headers
apt install pve-headers-4.15.18-9-pve
Then install the driver
Now everything works
gusto
