What I need? Please explain to me
Postby Dadadu » Wed Dec 05, 2018 12:53 pm
Hi to all and thanks in advance for your attention.
I'm a newby in this subject and I need some tips.
So, I've regular subscription with a satellite tv provider.
My house is structured on three floors: me, my mothers and my sister...my intention is make available satellite tv program on every apartment with tvheadend using maybe.
My doubts: TBS6909X is it right for me? Can I use splitter for coaxial cable that came from parabola? If I consider to make a mini pc server to install TBS6909X what can I do to decrypted signal with my sat card? Do I have use an QBOX and if so, is it enough just one?
Thanks guy. I look forward to starting this project so any help is welcome.
EDIT I almost forgot: I would like to preserve the broadcasts in 4k
Dadadu
Re: What I need? Please explain to me
Postby steven » Thu Dec 06, 2018 11:32 am
You can using our tuner card streaming the chanenls with tvheadend to your LAN then all device inside the LAN you can
success watch , the problem is for the encrypted channels you need to use the right CAM + smart card with our TBS6590 it is dual
tuner support two CAM at the same time , you can streaming 2xtransponder channels .
more information you can find here :
https://www.tbsiptv.com/tbs6590-multi-standard-dual-tuner-dual-ci-pci-e-card
Postby Dadadu » Thu Dec 06, 2018 11:58 pm
Very thanks
Dadadu
Postby Dadadu » Fri Dec 07, 2018 12:03 am
it could seems very stupid but, how can I know what cam i need for?
Dadadu
Postby steven » Fri Dec 07, 2018 11:13 am
you can check the encryption way at here :
https://www.lyngsat.com/Astra-1KR-1L-1M-1N.html
MPEG-4/HD
Irdeto
Nagravision
Viaccess
Videoguard
or you can ge the ca system id check then check what CAM you will need to use .
