1 server con 2 tbs6909 funciona solo una en tvheadend
Postby neo0call » Wed Nov 28, 2018 7:18 pm
hello, I need help for my little knowledge in the subject, friends I have an Ubuntu server 18.10 with two tbs6909 cards, it works only once, if I use lspci I figure in the list of two, but on TV I head the figure only Adapter 9 to adapter 15, and also on that plate that if it appears to me, only the band antenna ku works and my antenna band c does not scan the transponder.
neo0call
Re: 1 server con 2 tbs6909 funciona solo una en tvheadend
Postby steven » Thu Nov 29, 2018 11:09 am
hi
if possible can you send the whole dmesge log to us we will have a check ,
and you can have a try connect the extra power of the 6909 make sure the power is enough
Postby neo0call » Thu Nov 29, 2018 11:19 pm
[ 51.151984] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 51.152124] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 51.275347] TBSECP3 driver 0000:06:00.0: MAC address 00:22:ab:91:fe:c1
[ 51.275357] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 51.275434] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 51.394791] TBSECP3 driver 0000:06:00.0: MAC address 00:22:ab:91:fe:c2
[ 51.394798] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 51.394871] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 51.517932] TBSECP3 driver 0000:06:00.0: MAC address 00:22:ab:91:fe:c3
[ 51.517938] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 51.518020] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 51.641050] TBSECP3 driver 0000:06:00.0: MAC address 00:22:ab:91:fe:c4
[ 51.641056] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 4 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 51.641135] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 51.764139] TBSECP3 driver 0000:06:00.0: MAC address 00:22:ab:91:fe:c5
[ 51.764145] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 5 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 51.764221] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 51.887234] TBSECP3 driver 0000:06:00.0: MAC address 00:22:ab:91:fe:c6
[ 51.887240] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 6 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 51.887314] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 52.010331] TBSECP3 driver 0000:06:00.0: MAC address 00:22:ab:91:fe:c7
[ 52.010337] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 7 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 52.010417] TBSECP3 driver 0000:06:00.0: TurboSight TBS 6909 DVB-S/S2 : PCI 0000:06:00.0, IRQ 38, MMIO 0xf7a00000
[ 52.010551] TBSECP3 driver 0000:07:00.0: TurboSight TBS 6909 DVB-S/S2
[ 52.011283] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 52.134320] TBSECP3 driver 0000:07:00.0: MAC address 00:22:ab:91:ff:30
[ 52.169535] Hydra chip version 2
[ 52.175573] loading firmware, please wait...
[ 77.581670] Hydra FW alive
[ 77.643154] chipID=00000001
[ 77.644797] chipVer=00000002
[ 77.646447] FWVer=0202010a
[ 77.684317] TBSECP3 driver 0000:07:00.0: DVB: registering adapter 8 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 77.684441] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 77.766771] TBSECP3 driver 0000:07:00.0: MAC address 00:22:ab:91:ff:31
[ 77.766781] TBSECP3 driver 0000:07:00.0: DVB: registering adapter 9 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 77.766857] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 77.889894] TBSECP3 driver 0000:07:00.0: MAC address 00:22:ab:91:ff:32
[ 77.889900] TBSECP3 driver 0000:07:00.0: DVB: registering adapter 10 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 77.889988] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 77.970763] TBSECP3 driver 0000:07:00.0: MAC address 00:22:ab:91:ff:33
[ 77.970769] TBSECP3 driver 0000:07:00.0: DVB: registering adapter 11 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 77.970842] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 78.093929] TBSECP3 driver 0000:07:00.0: MAC address 00:22:ab:91:ff:34
[ 78.093937] TBSECP3 driver 0000:07:00.0: DVB: registering adapter 12 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 78.094035] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 78.174808] TBSECP3 driver 0000:07:00.0: MAC address 00:22:ab:91:ff:35
[ 78.174816] TBSECP3 driver 0000:07:00.0: DVB: registering adapter 13 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 78.174912] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 78.298067] TBSECP3 driver 0000:07:00.0: MAC address 00:22:ab:91:ff:36
[ 78.298076] TBSECP3 driver 0000:07:00.0: DVB: registering adapter 14 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 78.298171] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 78.378771] TBSECP3 driver 0000:07:00.0: MAC address 00:22:ab:91:ff:37
[ 78.378779] TBSECP3 driver 0000:07:00.0: DVB: registering adapter 15 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 78.378870] TBSECP3 driver 0000:07:00.0: TurboSight TBS 6909 DVB-S/S2 : PCI 0000:07:00.0, IRQ 35, MMIO 0xf7900000
[ 78.485552] TBSECP3 driver 0000:07:00.0: DVB: adapter 9 frontend 0 frequency 0 out of range (300000..2350000)
[ 78.486140] TBSECP3 driver 0000:07:00.0: DVB: adapter 10 frontend 0 frequency 0 out of range (300000..2350000)
[ 78.486552] TBSECP3 driver 0000:07:00.0: DVB: adapter 11 frontend 0 frequency 0 out of range (300000..2350000)
[ 78.486901] TBSECP3 driver 0000:07:00.0: DVB: adapter 12 frontend 0 frequency 0 out of range (300000..2350000)
[ 78.487245] TBSECP3 driver 0000:07:00.0: DVB: adapter 13 frontend 0 frequency 0 out of range (300000..2350000)
[ 78.487571] TBSECP3 driver 0000:07:00.0: DVB: adapter 14 frontend 0 frequency 0 out of range (300000..2350000)
[ 78.487898] TBSECP3 driver 0000:07:00.0: DVB: adapter 15 frontend 0 frequency 0 out of range (300000..2350000)
[ 2834.604393] TBSECP3 driver 0000:07:00.0: DVB: adapter 11 frontend 0 frequency 5996000 out of range (300000..2350000
neo0call
Postby steven » Fri Nov 30, 2018 11:07 am
From the log two 6909 both init well ,can you set a teamview remote to our support@tbsdtv.com our engineer will have a remote check with your
6909
Postby marcosgollmann » Tue Dec 18, 2018 9:12 am
I do not understand very well in English, do you need a remote access to my tvheadend?
marcosgollmann
Postby steven » Thu Dec 20, 2018 3:13 pm
yea you can send email to our support and provide your teamview remote we can have a remote check
