TBS 5520SE with EBSpro (Win 7 x64)
Postby Satman75 » Wed Nov 07, 2018 9:52 pm
Hallo to all of you.
First time i have such a problem with TBS card .My PC has Win 7 x64 and i installed successfully the Windows driver v 1.0.0.7.
After that i started the EBSpro. It recognized the card but without making a blindscan or RF Scan. At this moment i have to say that i already change the StreamReader files to v. 1.2.4.32.
I check the card and with TBS Blindscan v.3.0.1.9. Also it recognized the card but when i select it show me a message that the card doesn't support blindscan.
My question is : Which is the right combination of windows driver with streamreader for Win 7 x64 to work fine this card.
Thanks in advanced
Satman75
Re: TBS 5520SE with EBSpro (Win 7 x64)
Postby steven » Tue Nov 13, 2018 11:06 am
For 5520se do not have Blindscan support so you can not use the TBS Blind scan .
but you can have a try with crazyscan :
https://sourceforge.net/projects/crazyscan/
Postby Satman75 » Wed Nov 14, 2018 6:38 pm
Thanks Steven for your reply
I just make a scan with Crazyscan tool (v.1.0.2.160) with streamreader v. 1.2.4.69.
First time i make a " reception " with TBS 5520se
Exist a new issue now. The card shows me wrong tps. For example i made an RF Scan (19.2E 12500 - 12750 Ver ) and shows me tps that aren't exists (12628 Ver ) Any solution for this pls.
Thanks in advanced
Satman75
Postby Satman75 » Thu Nov 15, 2018 12:41 pm
The active freq. is at 11778 Ver but blindscan freq is 12628 Ver as my previous screenshot shows.
We have a difference of 850 MHz. What are the correct LNB settings for this problem ????
Thanks in advanced
Satman75
Postby AsaGong » Tue Mar 02, 2021 11:25 pm
Hi...on the off chance that an examination is to be made,then tbs5925 USB should be contrasted with tbs6925 card, which are from a similar mechanical generation(2010).Tbs5927 USB is a sort of overhaul of tbs5925 and clearly is more performant in numerous way.It is invested with a fan against warmth and accordingly the gadget is ensured.
While tbs5927 USB and tbs6903 card have about a similar equipment and of a similar tech generation.As such it is smarter to contrast between these two than and 5925! They are from another era,to misrepresent a bit.
However, one thing needs to know,because of actual development and association mode,the dvbs card introduced in the PC is quicker at examining than a USB device.It is a benefit that dvbs cards have when working in a PC climate.
pcb assembly quote
AsaGong
