TBS6522 unicable support
Postby oldgringo » Sun Sep 23, 2018 11:08 pm
Does TBS6522 support unicable LNB?
oldgringo
Re: TBS6522 unicable support
Postby oldgringo » Wed Sep 26, 2018 6:40 am
Simple question, 17 views, no answer? :?
oldgringo
Postby steven » Thu Sep 27, 2018 9:28 am
yes no problem ,unicable is send diseqc command just need software support which application you are using ?
Postby oldgringo » Fri Sep 28, 2018 7:29 am
DvbViewer. I can't get working even TransEdit, still no signal from lnb.
oldgringo
Postby steven » Sun Sep 30, 2018 10:28 am
Please have a try with DVBDream :
http://www.tbsiptv.com/download/common/dvbdream_oem_version_setup_v2952.zip
Postby oldgringo » Mon Oct 01, 2018 6:52 am
Does it really support unicable including support of multiple sat. positions or only basic unicable LNB support (power + userband)? What version of unicable is supported? Because I cannot see diseqc changes for A/B/C/D (not even A/B) here. I am trying 2/4 sat positions (both unicable I & II) but no luck.
oldgringo
Postby daowei » Tue Oct 09, 2018 11:20 pm
oldgringo Wrote:Does it really support unicable including support of multiple sat. positions or only basic unicable LNB support (power + userband)? What version of unicable is supported? Because I cannot see diseqc changes for A/B/C/D (not even A/B) here. I am trying 2/4 sat positions (both unicable I & II) but no luck.
Sorry for delay.
Yes, this tuner card did support Unicable & multiple satellite. For DVBdream, the Diseqc setting like this:
1> Go to option "Option"-----"Diseqc".
2> Here you can set Diseqc for "multiple satellite" and also "Unicable". More detailed, please check my attachments.
For the Unicable, Unicable I "SCR 0-7 EN50494 is working". But Unicable II "EN50607" not sure, need to test. Any question you'd better write to us directly:
support@tbsdtv.com
daowei@tbsdtv.com
Diseqc_setting.zip
(117.76 KiB) Downloaded 1438 times
Postby oldgringo » Thu Oct 18, 2018 2:44 am
I sent an email on Sunday but no reaction since then :!:
The driver is hard to capable unicable II if there are only unicable I user bands in the settings. The driver under windows 10 is - simply said - UGLY. Veeeery slow, action to tune request is more less accidental. Once I changed the diseqc switch to more than simple diseqc the driver didn't responding to tune commands. I am very disappointed from this buy. From >160 Euro card I would expect way different level of support. It's the worst supported pcie card I tested for the last ten years. I have to say it is a real shame. :evil:
oldgringo
Postby oldgringo » Sun Oct 28, 2018 2:28 am
2 weeks later - no response. :(
oldgringo
Postby steven » Fri Nov 02, 2018 11:26 am
My colleague reply you last month but not get reply yet
Please prepare a teamviewer, we'll check for you. I also invited our driver Engineer join us,
that will be helpful.
daowei@tbsdtv.com
please have a check
