[ Moderator Control Panel ]
by jpeg73 » Tue Aug 28, 2018 10:14 pm
hi ,
In DVB-T mode , is TBS6590 able to provide small amount of energy (I need 60mA between 4-12V) to a DVBT amplifier connected serially on the line ?
Thanks in advance
JP
jpeg73
by steven » Thu Aug 30, 2018 10:15 am
60mA between 4-12V is not enough
by jpeg73 » Thu Aug 30, 2018 6:14 pm
I need to provide 60mA under 12V to the amplifier
Did you mean the card , cannot ? and I need external powersupply ?
Is that correcT ?
THX
JP
jpeg73
by steven » Fri Aug 31, 2018 9:40 am
yea if your amplifier need power supply then you need external power for your amplifier
