[ Moderator Control Panel ]
by ashok1975 » Sun Aug 05, 2018 10:37 pm
i Have Moi Pro V
with 5 octa TBS6909 dvb-s/s2
1 octa TBS6209 DVB-C
Quattro LNB v/l h/l v/h h/h
Diseqc Multiswitch DMS 17/32
connected to
Poort A = 28.2E : Astra 2A/2C/2E/2F/Eutelsat 28A
Poort B = 19.2E : Astra 1KR/1L/1M/1N
Poort C = 23.5E : Astra 3B
Poort D = 13E : Eutelsat Hot Bird 13B/13C/13D
/etc/modprobe.d/mxl58x.conf
options mxl58x mode=0 (according tbs6909_user_guide.pdf)
i cant scan all channels from satelite with tvheadend (missing a lots of channels)
i think this has to do with dvblast (what i dont understand)
please help me
ashok1975
by daowei » Mon Aug 06, 2018 11:42 am
ashok1975 Wrote:i Have Moi Pro V
connected to
please help me
Hi ashok,
Please leave message to my Skype when you're ready, let's check again. And did you try conenct signal direct to the tuner card? what will
happen in this case? I want to know the defference between signal connect directly or after through the switch.
For the DVBlast, it's a streaming sofware also. It supports command line, it's faster than Tvheadend, so i'd like to test the transponder valid or not in it first. I can get the result in a few seconds, but Tvheadend can't.
Return to MOI Pro
