how to install or add tbs5520se driver in openpctv ?
Postby momi133 » Tue Jul 17, 2018 4:44 pm
Hi friends
I successfully installed openpctv on usb storage 8 gig.
but usb card (tbs 5520se) driver is not recognised and detected. and in tuner configuration,does not show my tuner, so can't scan any frequency.
by a Ubuntu Linux OS, I added tbs 5520se driver (tbs5520se.fw) to firmware folder of my usb storage(openpctv is installed on this sub storage ), but tbs usb card is not detected.
my question: how can I install tbs 5520se driver?
how can I access to Linux base OS platform or command line to install driver manually ?
momi133
Re: how to install or add tbs5520se driver in openpctv ?
Postby steven » Fri Aug 31, 2018 2:09 pm
You just need install the driver as normal please try like this :
#wget http://www.tbsdtv.com/download/document/linux/media_build-2018-0822.tar.bz2
#tar jxvf media_build-2018-0822.tar.bz2
#cd media_build
#./install.sh
#reboot
