tbs 2603. Problem with multicast stream to wisi chameleon
Postby dimka88 » Tue Jul 10, 2018 4:30 pm
Hi, I have problem with multicast h264 stream, image freezing and sound is robovoices (out Wisi chameleon DVB-C). I analyze stream with StreamExpert, match many errors "Priority 1" Continiuty count error.
Can you help me?
dimka88
Re: tbs 2603. Problem with multicast stream to wisi chameleo
Postby steven » Tue Jul 17, 2018 10:09 am
Which firmware version you are using with your 2603 ?
Postby dimka88 » Tue Jul 17, 2018 4:16 pm
steven Wrote:Hi
HI, I use latest FW 1.1.64
dimka88
Postby dimka88 » Mon Oct 01, 2018 3:31 pm
Hi. Any ideas how to fix h264 output without errors?
dimka88
Postby daowei » Sat Oct 06, 2018 11:31 am
dimka88 Wrote:Hi. Any ideas how to fix h264 output without errors?
Verison 1.1.64 should be ok, we also have customers who take this Encoder as the source of DVBC Modulator. Which multicast you use?
it's UDP or RTP?
We have another newer firmware version 1.1.87, please try.
tbs2603_firmware_v1.1.87.zip
firmware v_1.1.87 for TBS2603
(3.04 MiB) Downloaded 892 times
Postby Mike » Wed Oct 24, 2018 6:23 pm
Ive not been able using the tbs 2603 encoder for over an year now as it doesnt work with Twitch, and so encoding with my pc.
Could you give any timeframe or how long before there is a firmware with possibility to stream to Twitch and other platforms (youtube, facebook)?
Mike
Postby daowei » Fri Oct 26, 2018 11:04 am
Mike Wrote:Ive not been able using the tbs 2603 encoder for over an year now as it doesnt work with Twitch, and so encoding with my pc.
We have tested, this encoder did supoprt Twitch, please refer this forum to set it:
viewtopic.php?f=187&t=25051&p=54263#p54263
Postby daowei » Tue Dec 31, 2019 10:17 am
Hi Mike,
We have a new Encoder named TBS2603SE, it supports Youtube, Twitch, Facebook (rtmps),vimeo and etc. Please have a look:
https://www.tbsdtv.com/products/tbs2603 ... coder.html
