The server initializes successfully this CAM Module.
uname -r
- 4.4.86-1.el7.elrepo.x86_64
dmesg | grep CA
- Code: Select All Code
[6.455229] TBSECP3 driver 0000: 05: 00.0: initializing CA slot 0 on adapter 0
[6.683503] TBSECP3 driver 0000: 05: 00.0: initializing CA slot 1 on adapter 1
[13.285004] dvb_ca_en50221: dvb_ca_en50221_parse_attributes: Valid DVB CAM detected MANID: 2c9 DEVID: 101 CONFIGBASE: 0x200 CONFIGOPTION: 0x1
[13.285465] dvb_ca_en50221: dvb_ca_en50221_thread: DVB CAM validated successfully
[13.286850] dvb_ca_en50221: dvb_ca_en50221_read_data: Received CA packet for slot 0 connection id 0x1 last_frag: 1 size: 0x2
[13.288523] dvb_ca_en50221: dvb_ca_en50221_write_data: Wrote CA packet for slot 0, connection id 0x1 last_frag: 1 size: 0x2
[13.288846] TBSECP3 driver 0000: 05: 00.0: CA slot enabled for adapter0
[13.288849] dvb_ca_en50221: dvb_ca adapter 0: DVB CAM detected and initialised successfully
When running tvheadend in DVBInputs, there is no ca0 device.
When you run gnutv-cammenu, there is no output.
dmesg | grep CA
[79600.801262] TBSECP3 driver 0000: 05: 00.0: CA slot disabled for adapter0
[79602.325514] dvb_ca_en50221: dvb_ca_en50221_parse_attributes: Valid DVB CAM detected MANID: 2c9 DEVID: 101 CONFIGBASE: 0x200 CONFIGOPTION: 0x1
[79602.325996] dvb_ca_en50221: dvb_ca_en50221_thread: DVB CAM validated successfully
[79622.426767] dvb_ca_en50221: dvb_ca adapter 0: DVB CAM did not respond :(
When I run dvblast instead of tvheadend, I see : DVB CAM did not respond
Updated successfully the driver to the latest version of tbs-linux-drivers_v170330.zip
But the CAM module does not work. Tell me what could be the problem?
