TBS6814 isdbt Linux Drivers and github drivers not working
Postby PortalNET » Fri May 25, 2018 11:03 am
Hi Steven
could you please check ubuntu-server 16.04 LTS x64 with Kernel 4.15.0-20
i compile with uname-a for my kernel 4.15.0.20, it compiles ok with no errors, but after reboot and after install firmware 1.0.b in /lib/firmware cards do not get detected neither 6814 isdbt or tbs6909..
i have posted logs output on other topic ot Isdbt, perhaps you could test this as i think it could be kernel version.
also tested on another pc server ubuntu-server 14.04.05 LTS with kernel 4.4.30 on this version TBS6909 and isdbt 6814 are not recongnised or working..
maybe its a faul github not sure, maybe compile inside different folder default?
the only way i can get the TBS6909 working perfect is followin crazycat build source, but still also on the other machine with other isdbt card 6814 it also does not get recognised neither started..
if necessary i can provide ssh login credentials to both machines for testing..
crazycat build has build script works but only for tbs6909
cd /usr/src
git clone --depth=1 https://bitbucket.org/CrazyCat/media_build
cd /usr/src/media_build
./build
make install
github tbs build from github not detected and not working on dmesg on any of the cards, this happens in both ubuntu-server 14.04lts 4.4.30 kernel and ubuntu 16.04 lts kernel 4.15.0.20
cd media_build
make dir DIR=../media
make allyesconfig
make -j4
sudo make install
sudo reboot
PortalNET
Re: TBS6814 isdbt Linux Drivers and github drivers not worki
Postby PortalNET » Sat May 26, 2018 12:13 am
Hi steven
quick update
i have tested compile now on github again looks like something has been updated now after reboot
new ISDB-T drivers show up on ubuntu 14.04.5 lts x64 kernel 4.4.0.31 generic, will now test again on the other server machine where i have another 2 tbs6909 + 1 isdb-t 6814 the one running ubuntu 16.04 + kernel 4.15.0.20
TBSECP3 driver (544:6178 6909:1) on PCI Domain:0 Bus:5 Device:0 Function:0
DEVICE:0 ADAPTER:4 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
FE_QPSK Fmin=950MHz Fmax=2150MHz
DEVICE:0 ADAPTER:24 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:0 FRONTEND:0 (Turbosight TBS 6814 (Quad ISDB-T))
FE_OFDM Fmin=76MHz Fmax=858MHz
DEVICE:0 ADAPTER:20 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:17 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:13 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:7 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:27 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:3 FRONTEND:0 (Turbosight TBS 6814 (Quad ISDB-T))
DEVICE:0 ADAPTER:23 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:16 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:12 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:6 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:26 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:2 FRONTEND:0 (Turbosight TBS 6814 (Quad ISDB-T))
DEVICE:0 ADAPTER:22 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:19 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:15 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:11 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:9 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:5 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:25 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:1 FRONTEND:0 (Turbosight TBS 6814 (Quad ISDB-T))
DEVICE:0 ADAPTER:21 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:18 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:14 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:10 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
DEVICE:0 ADAPTER:8 FRONTEND:0 (TurboSight TBS 6909 DVB-S/S2 )
PortalNET
Postby PortalNET » Sat May 26, 2018 12:30 am
update
after re-install on ubuntu 16.04 after full reboot
still drivers not recognised
ls /dev/dvb
ls: cannot access '/dev/dvb': No such file or directory
root@iptv-work:/etc# lspci | grep Multimedia
01:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
02:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
03:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
PortalNET
Postby crazycat » Sat May 26, 2018 3:38 am
dmesg
Postby PortalNET » Sat Jun 02, 2018 12:26 am
crazycat Wrote:dmesg
hiya o dmesg it stays blank..
but if i do gre multimidia it shows the 3 DVB tunners insterted on that machine 2 TBS6909 and 1 TBS6814
PortalNET
Postby steven » Tue Jun 05, 2018 2:30 pm
Hi PortalNET
From another topic it is like you success install the driver , is it ok now ?
Postby PortalNET » Wed Jun 06, 2018 12:29 am
steven Wrote:Hi PortalNET
Hi stevens
2 different setups
1st setup running on machine ubuntu 14.04 server with 3 TBS6909 + 1TBS6814 = this setup ok recognise tbs6814 and works, but have problem with TBS6909 tunner after 4 hours start crashing and getting error kernel timeout 2xc error.
The other setup is another server machine with 2 TBS6909 + 1 TBS6814 this one is running on ubuntu 16.04 lts version, tbs6909 tunner driver compiled from linux source github ok recognised, but TBS6814 driver still not recognised this is the one i opened this topic for..
PortalNET
Postby steven » Wed Jun 06, 2018 4:56 pm
Hi PortalNET
Thanks for your update , for your both server can you have a try only use 6909 ? and for driver please try this one :
#wget http://www.tbsdtv.com/download/document ... 25.tar.bz2
#tar jxvf media_build-2018-05-25.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby lealpa » Wed Dec 11, 2019 1:15 am
Hello!
I'm struggling to have my TBS6814 to work on Astra. On TVHeadend I managed to have 4 channels running, but on Astra is very unstable, can't have more than two channels at once, if I do image is degraded on all of them.
Server runs on Ubuntu 18.04 LTS Server Edition, Is there any trick? I was told that 6814 won't work fine in Brazil, does it makes any sense?
Please, help me, I'm freaking out!
Thanks,
LP
lealpa
