Open source driver breaks usb webcam. (Ubuntu 16.04)
Postby Fiddlesticks » Sat May 19, 2018 6:09 am
New(ish) install of 16.04 and installed the open source driver for the TBS6280. Before installation the usb webcam worked fine. Afterwards it is not available in Cheese / Skype etc.
Webcam is a Logitech C270. It has worked previously.
dmesg here: https://pastebin.com/H36zMdSi
# uname -a
Linux myth 4.13.0-41-generic #46~16.04.1-Ubuntu SMP Thu May 3 10:06:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
# lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.4 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 5 (rev c4)
00:1c.5 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 6 (rev c4)
00:1c.6 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 7 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation H77 Express Chipset LPC Controller (rev 04)
00:1f.2 IDE interface: Intel Corporation 7 Series/C210 Series Chipset Family 4-port SATA Controller [IDE mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
00:1f.5 IDE interface: Intel Corporation 7 Series/C210 Series Chipset Family 2-port SATA Controller [IDE mode] (rev 04)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 09)
04:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
05:00.0 IDE interface: Marvell Technology Group Ltd. 88SE9172 SATA III 6Gb/s RAID Controller (rev 11)
# lsusb
Bus 002 Device 005: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 002 Device 004: ID 1058:1001 Western Digital Technologies, Inc. Elements Desktop (WDE1U)
Bus 002 Device 003: ID 20e8:5861
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 005: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 004: ID 05e3:070e Genesys Logic, Inc. USB 2.0 Card Reader
Bus 001 Device 003: ID 15c2:0036 SoundGraph Inc. LC16M VFD Display/IR Receiver
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Can anyone help?
Fiddlesticks
Re: Open source driver breaks usb webcam. (Ubuntu 16.04)
Postby steven » Fri May 25, 2018 9:57 am
When you install the driver do you delete the media folder ? if yes please have a try do not delete check whether is ok
thanks
Postby Fiddlesticks » Mon Jun 11, 2018 1:14 am
I have tried it both ways. As soon as the install completes successfully the webcam fails.
Fiddlesticks
