TBS6985 With Debian 4.9.0.6 - error
Postby Peque » Sat Mar 03, 2018 7:35 pm
Hi Guys.
I'm reinstalling my MythTV server and ran into this problem.
After reinstalling my Server - with a fresh debian Stable - and upgrade all settings and added the Debian Multimedia source
I've downloadet the latest driver v.170330 - and installed this with no errors
after rebooting - no dvb devices found and this in error log:
lspci:
06:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 02)
[    2.764481] tbs6290fe: module license 'TurboSight Proprietary' taints kernel.
[    2.764482] Disabling lock debugging due to kernel taint
[    2.765129] IR LIRC bridge handler initialized
[    2.768318] saa716x_core: disagrees about version of symbol dvb_dmxdev_init
[    2.768320] saa716x_core: Unknown symbol dvb_dmxdev_init (err -22)
[    2.768430] saa716x_core: disagrees about version of symbol dvb_register_adapter
[    2.768431] saa716x_core: Unknown symbol dvb_register_adapter (err -22)
[    2.768520] saa716x_core: disagrees about version of symbol dvb_dmx_release
[    2.768521] saa716x_core: Unknown symbol dvb_dmx_release (err -22)
[    2.768568] saa716x_core: disagrees about version of symbol dvb_net_init
[    2.768570] saa716x_core: Unknown symbol dvb_net_init (err -22)
[    2.768592] saa716x_core: disagrees about version of symbol dvb_dmxdev_release
[    2.768593] saa716x_core: Unknown symbol dvb_dmxdev_release (err -22)
[    2.768637] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[    2.768639] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[    2.768649] saa716x_core: disagrees about version of symbol dvb_net_release
[    2.768650] saa716x_core: Unknown symbol dvb_net_release (err -22)
[    2.768676] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[    2.768677] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[    2.768704] saa716x_core: disagrees about version of symbol dvb_register_frontend
[    2.768705] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
[    2.768723] saa716x_core: disagrees about version of symbol dvb_unregister_adapter
[    2.768724] saa716x_core: Unknown symbol dvb_unregister_adapter (err -22)
[    2.768729] saa716x_core: disagrees about version of symbol dvb_dmx_init
[    2.768730] saa716x_core: Unknown symbol dvb_dmx_init (err -22)
My modules look like this - and when trying to load the modules manualy
# lsmod | grep 69
snd_hda_codec_generic    69632  1 snd_hda_codec_realtek
tbs6922fe              24576  0
tbs6928fe              20480  0
tbs6991se              20480  0
dvb_core              126976  0
oot@mythtv:~# modprobe  saa716x_core
modprobe: ERROR: could not insert 'saa716x_core': Invalid argument
root@mythtv:~# modprobe tbs6985fe
root@mythtv:~#
I've googlet and found another on this forum - removing kernel/drivers/media directory and reinstall the drivers once again.
But no matter what I'm getting stocked - and cannot see my DVB device on the server and keep getting this error above in dmesg.
It seems to only keep loading the wrong modules?
But not sure - how to fix this problem
My steps in this are:
Install debian net-install - ends up kernel 4.9.0.4
adding multimedia source - and contrib/nonfree to normal sources.
do a apt-get dist-upgrade
downloading the Drives - install them
then reboots
Peque
Re: TBS6985 With Debian 4.9.0.6 - error
Postby steven » Mon Mar 05, 2018 9:40 am
Please check the FAQ in the package
please delette the kernem media folder and try again
#sudo rm -rf /lib/modules/`uname -r`/kernel/drivers/media/
thanks
