Facebook and Youtube Live RMTP settings
Postby Peltove » Thu Dec 14, 2017 4:57 am
Has somebody working setup for streaming into Facebook and/or Youtube Live?
In case of Facebook, Server URL is rtmp://live-api.facebook.com:80/rtmp/ and in case of Youtube, server URL is rtmp://a.rtmp.youtube.com/live2
How to put these into TBS2630 RTMP configuration?
And where to put the stream key
Hopefully streaming into those services is possible. Otherwise the box is quite useless for me.
br,
Vesku
Peltove
Re: Facebook and Youtube Live RMTP settings
Postby echomay » Tue Dec 19, 2017 2:35 pm
You can try like this:(and you need to know the streamname, and the user name and the passwd too to put to the empty place, if there are no username and passwd asked by server, you can not put them.)
echomay
Postby Peltove » Thu Dec 21, 2017 5:04 pm
so far no luck.
RTMP stream name is the stream key from Facebook/Youtube Live settings as it is written?
What about static IP address (DNS) or DHCP?
Channel name doesn't affect to this?
The next step will be Wireshark and debugging the difference between 2603 and OBS in network traffic.
br,
Vesku
Peltove
Postby echomay » Mon Dec 25, 2017 11:09 am
I think the stream key may be some like passwd, you can set the streamname by yourself as for example "stream1", just add it into the url when you play like " rtmp://live-api.facebook.com:80/rtmp/stream1" .
And if still not ok, you can use nginx or wowza as rtmp server to test first. The Nginx and Wowza are both free to download.
echomay
Postby Peltove » Tue Jan 02, 2018 9:19 pm
Is character "-" allowed as a part of Stream name string? Stream name seems to be cutted when changing something in network settings. Youtube Live has stream key like XYXG-ASDF-FGHK-QWET
br,
Vesku
Peltove
Postby diabloss » Mon Oct 08, 2018 2:39 pm
The correct syntax should be like this:
rtmp://a.rtmp.youtube.com/live2/xxxx-xxxx-xxxx-xxxx
the xxxx-xxxx-xxxx-xxxx is the youtube streaming key
diabloss
