[ Moderator Control Panel ]
by UKWSMI » Thu Dec 07, 2017 8:02 pm
Is it possible to save/export the Dvblast settings or a full backup form the MOIPro-AMD V2.0.0.4 ?
Or can I copy the setting file from the root directory? And when it’s possible, where is the file located?
Thanks in advance
Sebastian
UKWSMI
by steven » Fri Dec 08, 2017 6:33 pm
Yea , all dvblast confige file is here:
/usr/local/tbs/apache2.4.3/htdocs/www/configs/dvblast/
You can have a check
by UKWSMI » Fri Dec 08, 2017 7:45 pm
Thank you very much for the quick answer!
UKWSMI
Return to MOI Pro - AMD
