TBS 5520se unicable no scan channel
Postby DJJaro » Tue Nov 28, 2017 3:47 pm
Hello.
I use this tuner on ubuntu 14.04 lts, HTS Tvheadend 4.1-2405~geb495a0~trusty and inverto unicable lnb
I am unicable user. I have problem scan mux with this function, except kernel: ii linux-image-4.4.0-34-generic, but this kernel working several minutes or hours and write to log retune error... without restart tvheadend not function... I read on the forums of is a kernel error. But after upgrade kernel to any last version, doesnt scan channels. tvheadend write to log:
2017-11-28 07:55:51.297 mpegts: 12070H in dvb-s - tuning on TurboSight TBS 5520SE DVB-S/S2/S2X : DVB-S #1
2017-11-28 07:55:51.671 subscription: 0004: "scan" subscribing to mux "12070H", weight: 6, adapter: "TurboSight TBS 5520SE DVB-S/S2/S2X : DVB-S #1", network: "dvb-s", service: "Raw PID Subscription"
2017-11-28 07:56:01.641 mpegts: 12070H in dvb-s - scan no data, failed
2017-11-28 07:56:01.641 subscription: 0004: "scan" unsubscribing
dmesg log:
[ 10.407118] dvb-usb: found a 'TurboSight TBS 5520SE' in warm state.
[ 10.407278] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 10.407604] dvbdev: DVB: registering new adapter (TurboSight TBS 5520SE)
[ 10.617123] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.701801] dvb-usb: MAC address: 00:22:ab:c0:45:87
[ 10.711548] i2c i2c-8: Added multiplexed i2c bus 9
[ 10.711555] si2183 8-0067: Silicon Labs Si2183 successfully attached
[ 10.716992] si2157 9-0061: Silicon Labs Si2147/2148/2157/2158 successfully attached
[ 10.719276] i2c i2c-9: av201x: Airoha Technology AV201x successfully attached
[ 10.721224] usb 2-1.1: DVB: registering adapter 0 frontend 0 (TurboSight TBS 5520SE DVB-T/T2/C/C2/ISDB-T)...
[ 10.721300] usb 2-1.1: DVB: registering adapter 0 frontend 1 (TurboSight TBS 5520SE DVB-S/S2/S2X)...
[ 10.721727] dvb-usb: TurboSight TBS 5520SE successfully initialized and connected.
[ 10.722149] usbcore: registered new interface driver tbs5520se
[ 11.038584] si2183 8-0067: found a 'Silicon Labs Si2183-B60'
[ 11.038742] si2183 8-0067: downloading firmware from file 'dvb-demod-si2183-b60-01.fw'
[ 11.063697] Adding 4026364k swap on /dev/mapper/cryptswap1. Priority:-1 extents:1 across:4026364k SSFS
[ 11.301508] si2183 8-0067: firmware version: 6.0.2
[ 11.320255] si2157 9-0061: found a 'Silicon Labs Si2157-A30'
[ 11.345148] si2157 9-0061: firmware version: 3.0.5
[ 11.345189] usb 2-1.1: DVB: adapter 0 frontend 0 frequency 0 out of range (174000000..862000000)
[ 11.559402] usb 2-1.1: DVB: adapter 0 frontend 1 frequency 0 out of range (950000..2150000)
dvb-t tuner working fine...
I use actual kernel 4.7.0-040700rc3-generic. This kernel is in instruction...
I have installed driver from here: https://github.com/tbsdtv/linux_media/wiki
Other drivers on this forum not support 5520"SE" tuner...
Thank you for solution my problem.
DJJaro
Re: TBS 5520se unicable no scan channel
Postby smile » Thu Nov 30, 2017 4:06 pm
Do you link the dvr0 ,demux0 and net0?
such as : ln dvr0 dvr 1
smile
Postby DJJaro » Fri Dec 01, 2017 2:42 am
Hello
First, thank you for your repply :)
Answer: Yes...
root@ubuntu:~# cd /dev/dvb/adapter0
root@ubuntu:/dev/dvb/adapter0# ln -s demux0 demux1
root@ubuntu:/dev/dvb/adapter0# ln -s dvr0 dvr1
root@ubuntu:/dev/dvb/adapter0# ln -s net0 net1
Tvheadend say:
2017-11-30 19:36:55.956 mpegts: 12070H in dvb-s - tuning on TurboSight TBS 5520SE DVB-S/S2/S2X : DVB-S #1
2017-11-30 19:36:56.330 subscription: 0004: "scan" subscribing to mux "12070H", weight: 6, adapter: "TurboSight TBS 5520SE DVB-S/S2/S2X : DVB-S #1", network: "dvb-s", service: "Raw PID Subscription"
2017-11-30 19:37:06.321 mpegts: 12070H in dvb-s - scan no data, failed
2017-11-30 19:37:06.321 subscription: 0004: "scan" unsubscribing
edit:
I installed new ubuntu 16.04 lts with 4.4.0.87 kernel to other PC (server) ... worked fine only few minutes and later write to log :
2017-11-30 23:18:10.180 mpegts: fastscan mux found '12070H in DVB-S Network', set scan state 'PENDING'
2017-11-30 23:18:10.181 mpegts: 12070H in DVB-S Network - tuning on TurboSight TBS 5520SE DVB-S/S2/S2X #0 : DVB-S #1
2017-11-30 23:18:10.697 diseqc: failed to send diseqc cmd (e=Connection timed out)
2017-11-30 23:18:10.697 en50494: error send tune command
edit2:
change USB port, this problem solved...
I do not know what this might be :( defective driver?
DJJaro
Postby DJJaro » Fri Dec 01, 2017 3:16 pm
edit3: the same problem as in kernels 4.4.0.32. After several minutes, dont working...
log:
ec 1 02:06:27 ubuntu tvheadend[1181]: TS: dvb-s/12363V/STV1 HD: H264 @ #5015 Continuity counter error (total 3)
Dec 1 02:06:27 ubuntu tvheadend[1181]: TS: dvb-s/12363V/STV1 HD: TELETEXT @ #5355 Continuity counter error (total 2)
Dec 1 02:06:27 ubuntu tvheadend[1181]: TS: dvb-s/12363V/STV1 HD: AC3 @ #5095 Continuity counter error (total 2)
Dec 1 02:06:27 ubuntu tvheadend[1181]: TS: dvb-s/12363V/STV1 HD: MPEG2AUDIO @ #5025 Continuity counter error (total 3)
Dec 1 02:06:27 ubuntu tvheadend[1181]: TS: dvb-s/12363V/STV1 HD: MPEG2AUDIO @ #5035 Continuity counter error (total 3)
Dec 1 02:06:27 ubuntu tvheadend[1181]: TS: dvb-s/12363V/STV1 HD: MPEG2AUDIO @ #5115 Continuity counter error (total 3)
Dec 1 02:06:28 ubuntu tvheadend[1181]: linuxdvb: TurboSight TBS 5520SE DVB-S/S2/S2X #0 : DVB-S #1 - retune
Dec 1 02:06:34 ubuntu tvheadend[1181]: linuxdvb: TurboSight TBS 5520SE DVB-S/S2/S2X #0 : DVB-S #1 - poll TIMEOUT
Dec 1 02:06:35 ubuntu tvheadend[1181]: linuxdvb: TurboSight TBS 5520SE DVB-S/S2/S2X #0 : DVB-S #1 - retune nodata
Dec 1 02:06:42 ubuntu tvheadend[1181]: linuxdvb: TurboSight TBS 5520SE DVB-S/S2/S2X #0 : DVB-S #1 - poll TIMEOUT
Dec 1 02:06:43 ubuntu tvheadend[1181]: linuxdvb: TurboSight TBS 5520SE DVB-S/S2/S2X #0 : DVB-S #1 - retune nodata
Dec 1 02:06:50 ubuntu tvheadend[1181]: linuxdvb: TurboSight TBS 5520SE DVB-S/S2/S2X #0 : DVB-S #1 - poll TIMEOUT
lsusb:
root@ubuntu:~# lsusb
Bus 002 Device 003: ID 734c:5521 TBS Technologies China
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
dmesg:
19.348939] si2157 9-0061: Silicon Labs Si2147/2148/2157/2158 successfully attached
[ 19.503073] i2c i2c-9: av201x: Airoha Technology AV201x successfully attached
[ 19.503083] usb 2-5: DVB: registering adapter 0 frontend 0 (TurboSight TBS 5520SE DVB-T/T2/C/C2/ISDB-T)...
[ 19.503148] usb 2-5: DVB: registering adapter 0 frontend 1 (TurboSight TBS 5520SE DVB-S/S2/S2X)...
[ 19.503188] dvb-usb: TurboSight TBS 5520SE successfully initialized and connected.
[ 19.503597] dvb-usb: TurboSight TBS 5520SE successfully deinitialized and disconnected.
[ 19.503715] usbcore: registered new interface driver tbs5520se
21.048641] usb 2-5: DVB: registering adapter 0 frontend 0 (TurboSight TBS 5520SE DVB-T/T2/C/C2/ISDB-T)...
[ 21.048712] usb 2-5: DVB: registering adapter 0 frontend 1 (TurboSight TBS 5520SE DVB-S/S2/S2X)...
[ 21.049010] dvb-usb: TurboSight TBS 5520SE successfully initialized and connected.
DJJaro
Postby DJJaro » Wed Dec 06, 2017 8:13 pm
hello new problem:
after update kerne 4.14.0 and after retune error, not linked dvb-s tuner:
see dmesg log:
[ 179.104155] si2183 8-0067: read_status failed=-11
[ 179.308152] si2183 8-0067: read_status failed=-11
[ 179.512154] si2183 8-0067: read_status failed=-11
[ 179.716162] si2183 8-0067: read_status failed=-11
[ 179.819347] si2183 8-0067: set_params failed=-11
[ 180.336379] si2183 8-0067: set_tone failed=-110
[ 180.336425] si2183 8-0067: read_status failed=-11
[ 180.540104] si2183 8-0067: read_status failed=-11
[ 180.748075] si2183 8-0067: read_status failed=-11
[ 181.870979] usb 2-1.1: DVB: adapter 0 frontend 0 frequency 0 out of range (17 4000000..862000000)
[ 510.176023] usb 2-1.1: DVB: adapter 0 frontend 0 frequency 0 out of range (17 4000000..862000000)
[ 608.211932] usb 2-1.1: DVB: adapter 0 frontend 0 frequency 0 out of range (17 4000000..862000000)
reboot this problem not solved... what is it?
DJJaro
Postby smile » Thu Dec 07, 2017 4:08 pm
would you mind set the remote control to us,and email to me( davin@tbsdtv.com)
Best Regards
smile
Postby DJJaro » Sun Dec 10, 2017 11:35 pm
Hello. I wrote mail to you from azet. All is ok to this time... Thank you.
DJJaro
Postby proseiko » Wed May 23, 2018 5:42 am
Do you mind telling me how you fixed it?
proseiko
Postby Ericed1965 » Sat Jul 21, 2018 5:48 pm
I have same error here :
kernel: [ 3810.953190] si2183 5-0067: read_status failed=-11
How can you fix it??
Thanks.
Ericed1965
Postby DJJaro » Sun Jul 21, 2024 2:22 am
Must be installed ONLY 1.0 version firmware... Only with this firmware working tvheadend OK.
DJJaro
