Few questions
Few questions
Postby TheTroll » Wed Nov 15, 2017 6:28 am
1) FAN noise
I see that there is a FAN on this board.
Is it noisy ? Can you hear it at all ?
2) Output signal
It was nice on the 6205 to have an output signal to chain the cards...
Why didn't you add it here ? And why did you use this kind of connector instead of the F one ?
TheTroll
Re: Few questions
Postby steven » Thu Nov 16, 2017 11:23 am
Hi TheTroll
Thanks for your interest of our product and for your question :
1. normally is ok ,if in a quite place you can hear .
2. As they are using different tuner and demo so for 6209 we have not add the loopout signal
Re: Few questions
Postby TheTroll » Fri Nov 17, 2017 5:46 am
Ok thanks!
TheTroll
Re: Few questions
Postby TheTroll » Thu Nov 30, 2017 6:20 pm
another one, could you please confirm if the external power is mandatory ?
I tested the card without it, and it looks like some tuners are stuck in the IOCTLs...
Thank
TheTroll
Re: Few questions
Postby TheTroll » Fri Dec 01, 2017 5:57 pm
Ok I found the issue, it was not due to the power supply.
The card does not like if we open all tuners at the same time, FW loading of all tuners must be done in sequence.
TheTroll
Re: Few questions
Postby steven » Tue Dec 05, 2017 4:12 pm
Hi TheTroll
Thanks for your update ,if the power from PCI-E slot not enough then need the extra power
Re: Few questions
Postby TheTroll » Sat Dec 08, 2018 9:57 pm
I got this board and the FAN makes a lot of noise :(
Can it work if I unplug it? Will it burn ?
TheTroll
Re: Few questions
Postby steven » Mon Dec 10, 2018 9:52 am
TheTroll Wrote:Hi,
What about your temprature enviroment if it is not hot then you can remove the FAN power .make sure the cooling from the server is well
Re: Few questions
Postby TheTroll » Mon Dec 10, 2018 9:45 pm
Ok thanks
TheTroll
Re: Few questions
Postby raptorjr » Fri Dec 14, 2018 7:12 pm
Is it possible to change for another cooling solution? Some different fan or something? I don’t need it to look pretty. Just be quite =)
raptorjr
