TBS 5990 - Ubuntu 17.10
Postby HybridNz » Tue Oct 31, 2017 10:32 am
Just completed an upgrade to Ubuntu 17.10 which obviously stopped the VL4 drivers from working.
I rebuilt from the media_build-0519 drivers .. Didnt compile and install.
I then downloaded from the tbs-linux-drivers_v170330 drivers .. followed the instructions in the read me but still have no drivers loaded.
I have another manufactures USB DVB installed which has been find through the whole process.
Is there a new V4L build for the 4.13.0-16 kernal used by Ubuntu 17.10 ?
thanks in advance.
 Linux pvr 4.13.0-16-generic #19-Ubuntu SMP Wed Oct 11 18:33:49 UTC 2017 i686 i686 i686 GNU/Linux
HybridNz
Re: TBS 5990 - Ubuntu 17.10
Postby steven » Wed Nov 01, 2017 3:59 pm
You can have a try with our latest open source driver :
of this open source offline pakcage :
#wget http://www.tbsdtv.com/download/document/linux/media_build-2017-1016.tar.bz2
#tar jxvf media_build-2017-1016.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby HybridNz » Thu Nov 02, 2017 1:38 pm
That worked great thanks! :)
thanks for your help.
HybridNz
Postby fatexs » Fri Nov 03, 2017 2:47 am
I got an 6618 card that is not supported by the open source driver...
I'm also on ubuntu 17.10 and I get errors compiling the lastest driver from the homepage:
/opt/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c: In function 'vbi_workaround':
/opt/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c:117:6: error: implicit declaration of function 'signal_pending'; did you mean 'timer_pending'? [-Werror=implicit-function-declaration]
   if(signal_pending(current)) {
      timer_pending
  CC [M]  /opt/tbs/linux-tbs-drivers/v4l/saa716x_fgpi.o
  CC [M]  /opt/tbs/linux-tbs-drivers/v4l/saa716x_adap.o
  CC [M]  /opt/tbs/linux-tbs-drivers/v4l/saa716x_gpio.o
/opt/tbs/linux-tbs-drivers/v4l/saa716x_pci.c: In function 'saa716x_enable_msix':
/opt/tbs/linux-tbs-drivers/v4l/saa716x_pci.c:49:8: error: implicit declaration of function 'pci_enable_msix'; did you mean 'pci_enable_msi'? [-Werror=implicit-function-declaration]
  ret = pci_enable_msix(pdev, saa716x->msix_entries, SAA716x_MSI_MAX_VECTORS);
        pci_enable_msi
Any update planned here? :)
Thanks!
fatexs
Postby steven » Fri Nov 03, 2017 9:56 am
Hi fatexs
TBS6618 is the older product if have time we have try to support at open source driver : )
Postby fatexs » Fri Nov 03, 2017 11:38 pm
steven Wrote:Hi fatexs
Thanks steven!
Much appreciated!
fatexs
Postby gogoa » Wed Nov 15, 2017 10:23 pm
I would like to add with the wish for support TBS6618 at open source driver too. (when it will be able.. I hope)
On Fedora26/27 is new kernel every month ... shortly - often...
Thanks you
gogoa
