Error on Kernel 4.12.12
Postby bennyg » Mon Oct 23, 2017 9:07 pm
Hello, I'm trying to reinstall my drivers on Gentoo, kernel 4.12.12. I get the following error:
make -C /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l
make[1]: Entering directory '/home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l'
No version yet, using 4.12.12-gentoo
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 4.12.12
./scripts/make_myconfig.pl
perl scripts/make_config_compat.pl /lib/modules/4.12.12-gentoo/source ./.myconfig ./config-compat.h
creating symbolic links...
make -C firmware prep
make[2]: Entering directory '/home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory '/home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/firmware'
make -C firmware
  CC  ihex2fw
Generating vicam/firmware.fw
Generating dabusb/firmware.fw
Kernel build directory is /lib/modules/4.12.12-gentoo/build
make -C /lib/modules/4.12.12-gentoo/build SUBDIRS=/home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l  modules
make[2]: Entering directory '/usr/src/linux-4.12.12-gentoo'
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tuner-xc2028.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tuner-simple.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tuner-types.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/mt20xx.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tda8290.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tea5767.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tda9887.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tda827x.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tda18271-maps.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tda18271-common.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tda18271-fe.o
  LD [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tda18271.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/xc5000.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/xc4000.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/mt2060.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/mt2266.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/qt1010.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/mt2131.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/mxl5005s.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/mxl5007t.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/mc44s803.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/max2165.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tda18218.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/tda18212.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/saa7146_i2c.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/saa7146_core.o
  LD [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/saa7146.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/saa7146_fops.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/saa7146_video.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/saa7146_hlp.o
  CC [M]  /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/saa7146_vbi.o
/home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c: In function 'vbi_workaround':
/home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c:117:6: error: implicit declaration of function 'signal_pending' [-Werror=implicit-function-declaration]
   if(signal_pending(current)) {
make[3]: *** [scripts/Makefile.build:303: /home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l/saa7146_vbi.o] Error 1
make[2]: *** [Makefile:1515: _module_/home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory '/usr/src/linux-4.12.12-gentoo'
make[1]: *** [Makefile:52: default] Error 2
make[1]: Leaving directory '/home/username/scripts/tbsdrivers/tbs/linux-tbs-drivers/v4l'
I'm using the latest driver (v170330)
bennyg
Re: Error on Kernel 4.12.12
Postby steven » Tue Oct 24, 2017 10:04 am
Sorry that for v170330 driver only support upto kernel 4.10 ,we are on add the 6928SE open source driver support now please check our open source driver some days later
Postby bennyg » Mon Oct 30, 2017 11:22 pm
steven Wrote:Hi
Okay, thanks for looking into it. I'll be waiting for the 6928 driver on github.
bennyg
Postby kosacik » Tue Sep 25, 2018 3:27 am
bennyg Wrote:
steven Wrote:Hi
well, it seems like we can wait forever.
I have the same card, unofrtunately, on kernel 4.15.0-29-generic and there is no driver You can use! Why not downgrade, yes? Well, i thanks to nvidia card i use.
Based on all I read, TBS support drivers only for kernels < 4.10, opensource drivers does not support this card.
I have experience with other cards, like 6905 and 6982se. And it was a pain to make them work. But they do work, somehow...
This little one will be throwed out of the window... Ok, i wanted to buy a new 4-tuner card anyway. But should it be TBS? DD has in-kernel built driver on linux kernel above 4.14... without this stupid driver building.
kosacik
Postby vaskos » Thu May 23, 2019 2:11 am
its already year 2019 , but still no support for 6928 . Is there any possibility how to install these drivers to 4.15 kernel ? Also opensource drivers are not supporting this card. TBS has very poor drivers support. we are waiting more than two years !!
vaskos
Postby Vispen74 » Fri Apr 10, 2020 2:42 am
And now it´s 2020, still no support for 6928. I wish I had the skills to contribute, but I havn´t.
Vispen74
Postby ichbinich » Mon Apr 20, 2020 3:00 pm
I am having a 6928SE and also looking for a driver that could be compiled with a more recent kernel, eg. 4.15 as used in Ubuntu 18.04 LTS. At the moment I am stuck to Ubutnu LTS 16.04 wit a 4.4 kernel due to the problems to compile the tbs-driver on 4.15. I have also tried the forked tbs driver but that one seems not to support the tbs6928se. Is there any chance to get a working driver for that card and a 4.15 kernel?
If not, I would have to buy a new card and guess what it will be not.
Best regards
ichbinich
