Blind Scan??
Blind Scan??
Postby broncano » Mon Oct 23, 2017 2:08 am
Is it possible to do a blind search with TBS 6903 ??
I have tried to do some searching on different satellites but find nothing ...
Can anyone tell me which parameters to place to search correctly?
I use the DVD Dream program.
Greetings.
broncano
Re: Blind Scan??
Postby steven » Mon Oct 23, 2017 10:46 am
Please have a try with TBS blindscan :
https://www.tbsiptv.com/download/common ... .0.2.1.zip
Re: Blind Scan??
Postby broncano » Mon Oct 23, 2017 9:51 pm
Hi Steven, thanks for responding.
I had not noticed the "Scan Auto" option and it seems that if it finds many channels.
Is there a way to know the keys? I can only see FTAs and some free feeds.
Greetings.
broncano
Re: Blind Scan??
Postby steven » Tue Oct 24, 2017 10:48 am
What do you mean the keys ?
Re: Blind Scan??
Postby broncano » Tue Oct 24, 2017 10:52 pm
For example, for this feed, these are the keys to be able to decrypt the channel and visualize it, sometimes I find them in Internet pages but I would like to know if I can find them with the blind search.
Satellite: Eutelsat 10A (10.0E)
Transponder: 11087 MHz
Polarization: Horizontal
Symbol Rate: 7202,06 Ks
FEC: 3/4
Standard: DVB-S2
HD 4:2:0
CW: C8 DB C7 6A DB C6 CB 6C <----------- KEYS
Regards.
broncano
Re: Blind Scan??
Postby steven » Wed Oct 25, 2017 11:16 am
Oh
Sorry that we can not get the key as this need to process the TS data
