DVB tuner lost after power outage
Postby martincnc » Fri Oct 20, 2017 10:06 pm
I have Ubuntu 16.04.3 with TBS 6205 QuadTuner PCI card
I installed drivers for PCI card, TVheadend app, everything worked (including after planned reboot)
But after power outage, dvb tuner lost (no devices on commands lsdvb; lspci |grep 6205). I have to install the drivers again. Again and again after every power outage!
How to fix this?
thanks for help
Martin
martincnc
Re: DVB tuner lost after power outage
Postby steven » Mon Oct 23, 2017 2:34 pm
When the device reboot is the kernel updated ? if the kernel update the driver need to reinstall you can disable the kernel
audo update .
and after reboot if can not find dvb please send the whole log dmesg and lspci -vvv log to our support@tbsdtv.com
we will have a check with this
