Open Source Driver with TBS 6285
Postby drphilth » Sun Oct 08, 2017 6:50 pm
I am having a problem with the TBS Open source driver on my TBS6285. The driver compiles and loads correctly, but I cannot tune any channels.
I'm running Ubuntu 16.04.3 with kernel version 4.4.0-96-generic.
I am in the UK and trying to view free-to-air DVB-T and DVB-T2.
An old version (I'm not sure how to find the revsion, but seems to be from Dec 2015) of the ljalves open source driver works well on my hardware, so I don't think it is a hardware problem.
w_scan tells me "Info: no data from PAT after 2 seconds" when I try to scan channels.
TVHeadend log shows this:
2017-10-08 11:20:54.833 linuxdvb: TurboSight TBS 6285 DVB-T/T2/C : DVB-T #3 - poll TIMEOUT
2017-10-08 11:21:02.515 linuxdvb: TurboSight TBS 6285 DVB-T/T2/C : DVB-T #0 - poll TIMEOUT
2017-10-08 11:21:05.000 subscription: 0004: "epggrab" unsubscribing
2017-10-08 11:21:05.007 subscription: 0003: "epggrab" unsubscribing
2017-10-08 11:21:05.015 subscription: 0002: "epggrab" unsubscribing
2017-10-08 11:21:05.024 subscription: 0001: "epggrab" unsubscribing
2017-10-08 11:21:06.000 mpegts: 514MHz in London - tuning on TurboSight TBS 6285 DVB-T/T2/C : DVB-T #3
2017-10-08 11:21:06.000 subscription: 0006: "epggrab" subscribing to mux "514MHz", weight: 4, adapter: "TurboSight TBS 6285 DVB-T/T2/C : DVB-T #3", network: "London", service: "Raw PID Subscription"
2017-10-08 11:21:06.001 mpegts: 545.833MHz in London - tuning on TurboSight TBS 6285 DVB-T/T2/C : DVB-T #0
2017-10-08 11:21:06.001 subscription: 0009: "epggrab" subscribing to mux "545.833MHz", weight: 4, adapter: "TurboSight TBS 6285 DVB-T/T2/C : DVB-T #0", network: "London", service: "Raw PID Subscription"
2017-10-08 11:21:07.098 linuxdvb: TurboSight TBS 6285 DVB-T/T2/C : DVB-T #3 - poll TIMEOUT
2017-10-08 11:21:37.844 linuxdvb: TurboSight TBS 6285 DVB-T/T2/C : DVB-T #0 - poll TIMEOUT
2017-10-08 11:21:41.000 subscription: 0009: "epggrab" unsubscribing
2017-10-08 11:21:41.023 subscription: 0006: "epggrab" unsubscribing
2017-10-08 11:28:37.086 linuxdvb: TurboSight TBS 6285 DVB-T/T2/C : DVB-T #3 - poll TIMEOUT
2017-10-08 11:28:41.000 subscription: 000A: service instance is bad, reason: No input detected
2017-10-08 11:28:41.008 mpegts: 529.833MHz in London - tuning on TurboSight TBS 6285 DVB-T/T2/C : DVB-T #2
2017-10-08 11:28:41.008 subscription: 000A: "HTTP" subscribing to service "London/529.833MHz/4Music", weight: 100, adapter: "TurboSight TBS 6285 DVB-T/T2/C : DVB-T #2", network: "London", mux: "529.833MHz", profile="pass", hostname="192.168.2.10", client="VLC/2.2.4 LibVLC/2.2.4"
LSPCI output for the card:
04:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 02)
        Subsystem: Device [6285:0001]
        Interrupt: pin A routed to IRQ 17
        Region 0: Memory at fe800000 (64-bit, non-prefetchable) [size=1M]
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
                LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
                LnkCtl: ASPM Disabled; RCB 128 bytes Disabled- CommClk-
        Kernel driver in use: SAA716x Budget
        Kernel modules: saa716x_tbs_dvb
dmesg shows the following
[    6.555788] dvbdev: DVB: registering new adapter (SAA716x dvb adapter)
[    6.564504] i2c i2c-3: Added multiplexed i2c bus 5
[    6.564512] si2168 3-0066: Silicon Labs Si2168-B40 successfully identified
[    6.564514] si2168 3-0066: firmware version: B 4.0.2
[    6.568122] Adding 4194300k swap on /dev/sda2.  Priority:-1 extents:1 across:4194300k SSFS
[    6.575711] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[    6.576021] SAA716x Budget 0000:04:00.0: TurboSight TBS 6285  MAC[1]=ff:ff:ff:ff:ff:ff
[    6.576025] SAA716x Budget 0000:04:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6285 DVB-T/T2/C)...
[    6.578627] dvbdev: DVB: registering new adapter (SAA716x dvb adapter)
[    6.585692] i2c i2c-2: Added multiplexed i2c bus 6
[    6.585694] si2168 2-0064: Silicon Labs Si2168-B40 successfully identified
[    6.585696] si2168 2-0064: firmware version: B 4.0.2
[    6.590977] si2157 6-0062: Silicon Labs Si2147/2148/2157/2158 successfully attached
[    6.591293] SAA716x Budget 0000:04:00.0: TurboSight TBS 6285  MAC[2]=ff:ff:ff:ff:ff:ff
[    6.591297] SAA716x Budget 0000:04:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6285 DVB-T/T2/C)...
[    6.592435] dvbdev: DVB: registering new adapter (SAA716x dvb adapter)
[    6.600349] i2c i2c-2: Added multiplexed i2c bus 7
[    6.600353] si2168 2-0066: Silicon Labs Si2168-B40 successfully identified
[    6.600354] si2168 2-0066: firmware version: B 4.0.2
[    6.603726] si2157 7-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[    6.604048] SAA716x Budget 0000:04:00.0: TurboSight TBS 6285  MAC[3]=ff:ff:ff:ff:ff:ff
[    6.604051] SAA716x Budget 0000:04:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6285 DVB-T/T2/C)...
[    9.898701] si2168 2-0066: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[   10.306091] si2168 2-0066: firmware version: B 4.0.25
[   10.310823] si2157 7-0060: found a 'Silicon Labs Si2158-A20'
[   10.312807] si2157 7-0060: downloading firmware from file 'dvb-tuner-si2158-a20-01.fw'
[   10.578648] si2157 7-0060: firmware version: 2.1.9
[   10.578699] SAA716x Budget 0000:04:00.0: DVB: adapter 3 frontend 0 frequency 0 out of range (42000000..870000000)
[   10.584050] si2168 2-0066: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[   10.612314] si2168 2-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[   11.455768] si2168 2-0066: firmware version: B 4.0.25
[   11.467982] si2168 2-0064: firmware version: B 4.0.25
[   11.474668] si2157 6-0062: found a 'Silicon Labs Si2158-A20'
[   11.474717] si2157 6-0062: downloading firmware from file 'dvb-tuner-si2158-a20-01.fw'
[   11.740528] si2157 6-0062: firmware version: 2.1.9
[   11.740574] SAA716x Budget 0000:04:00.0: DVB: adapter 2 frontend 0 frequency 0 out of range (42000000..870000000)
[   11.747742] si2168 2-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[   11.747954] si2168 3-0066: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[   12.165532] si2168 3-0066: firmware version: B 4.0.25
[   12.170716] si2157 5-0060: found a 'Silicon Labs Si2158-A20'
[   12.170742] si2157 5-0060: downloading firmware from file 'dvb-tuner-si2158-a20-01.fw'
[   12.170842] si2168 2-0064: firmware version: B 4.0.25
[   12.436572] si2157 5-0060: firmware version: 2.1.9
[   12.436621] SAA716x Budget 0000:04:00.0: DVB: adapter 1 frontend 0 frequency 0 out of range (42000000..870000000)
[   12.440794] si2168 3-0066: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[   12.441595] si2168 3-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
drphilth
Re: Open Source Driver with TBS 6285
Postby drphilth » Sun Oct 08, 2017 6:53 pm
For what its worth, here is the dmesg output from the working version of the driver:
[    5.963314] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[    5.963335] SAA716x Budget 0000:04:00.0: DVB: registering adapter 1 frontend 0 (Silicon Labs Si2168)...
[    5.963462] DVB: registering new adapter (SAA716x dvb adapter)
[    6.026235] i2c i2c-2: Added multiplexed i2c bus 6
[    6.026240] si2168 2-0064: Silicon Labs Si2168 successfully attached
[    6.091286] si2157 6-0062: Silicon Labs Si2147/2148/2157/2158 successfully attached
[    6.091306] SAA716x Budget 0000:04:00.0: DVB: registering adapter 2 frontend 0 (Silicon Labs Si2168)...
[    6.091432] DVB: registering new adapter (SAA716x dvb adapter)
[    6.098153] i2c i2c-2: Added multiplexed i2c bus 7
[    6.098158] si2168 2-0066: Silicon Labs Si2168 successfully attached
[    6.107187] si2157 7-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[    6.107205] SAA716x Budget 0000:04:00.0: DVB: registering adapter 3 frontend 0 (Silicon Labs Si2168)...
[    9.759806] si2168 2-0066: found a 'Silicon Labs Si2168-B40'
[    9.762412] si2168 2-0066: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[   10.169422] si2168 2-0066: firmware version: 4.0.25
[   10.172580] si2157 7-0060: found a 'Silicon Labs Si2158-A20'
[   10.174420] si2157 7-0060: downloading firmware from file 'dvb-tuner-si2158-a20-01.fw'
[   10.440264] si2157 7-0060: firmware version: 2.1.9
[   10.440315] SAA716x Budget 0000:04:00.0: DVB: adapter 3 frontend 0 frequency 0 out of range (42000000..870000000)
[   10.459422] si2168 2-0064: found a 'Silicon Labs Si2168-B40'
[   10.459481] si2168 2-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[   10.872249] si2168 2-0064: firmware version: 4.0.25
[   10.875419] si2157 6-0062: found a 'Silicon Labs Si2158-A20'
[   10.875455] si2157 6-0062: downloading firmware from file 'dvb-tuner-si2158-a20-01.fw'
[   10.950476] tg3 0000:06:00.0 em1: Link is up at 1000 Mbps, full duplex
[   10.950479] tg3 0000:06:00.0 em1: Flow control is on for TX and on for RX
[   10.950551] IPv6: ADDRCONF(NETDEV_CHANGE): em1: link becomes ready
[   11.143788] si2157 6-0062: firmware version: 2.1.9
[   11.143835] SAA716x Budget 0000:04:00.0: DVB: adapter 2 frontend 0 frequency 0 out of range (42000000..870000000)
[   11.149243] si2168 3-0066: found a 'Silicon Labs Si2168-B40'
[   11.149291] si2168 3-0066: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[   11.556319] si2168 3-0066: firmware version: 4.0.25
[   11.559485] si2157 5-0060: found a 'Silicon Labs Si2158-A20'
[   11.559502] si2157 5-0060: downloading firmware from file 'dvb-tuner-si2158-a20-01.fw'
[   11.825518] si2157 5-0060: firmware version: 2.1.9
[   11.825565] SAA716x Budget 0000:04:00.0: DVB: adapter 1 frontend 0 frequency 0 out of range (42000000..870000000)
[   11.835765] si2168 3-0064: found a 'Silicon Labs Si2168-B40'
[   11.835825] si2168 3-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[   12.243197] si2168 3-0064: firmware version: 4.0.25
[   12.246371] si2157 4-0062: found a 'Silicon Labs Si2158-A20'
[   12.246407] si2157 4-0062: downloading firmware from file 'dvb-tuner-si2158-a20-01.fw'
[   12.512693] si2157 4-0062: firmware version: 2.1.9
[   12.512740] SAA716x Budget 0000:04:00.0: DVB: adapter 0 frontend 0 frequency 0 out of range (42000000..870000000)
drphilth
Postby crazycat » Mon Oct 09, 2017 2:01 am
maybe you not set bandwidth 8MHz ?
Postby drphilth » Tue Oct 10, 2017 11:02 pm
crazycat Wrote:maybe you not set bandwidth 8MHz ?
w_scan checks both 7Mhz and 8Mhz. I get no results on 7Mhz (naturally). When searching 8 MHz it finds the muxes, but fails to tune them with the above error.
drphilth
Postby smile » Fri Oct 20, 2017 10:11 am
using the new driver, you need specifies the mode (DVBT or DVBT2)of the current frequency.
Best Regards
smile
Postby PeteM » Fri Oct 20, 2017 11:15 pm
This appears similar to an issue with the TBS6285 that I reported on github: https://github.com/tbsdtv/linux_media/issues/79
When I was investigating I also used dvbv5-scan from dvb-tools as well as mythtv-setup to exercise the tuner. Both of these take configuration for the multiplex so you don't get config discovery issues.
As a short term fix I ended up patching the old TBS official drivers so that they build and install with kernels 4.13.x. The old drivers work for me.
PeteM
Postby drphilth » Sat Oct 21, 2017 2:03 pm
smile Wrote:Hi
Best Regards
Hi smile,
How do we do this - I can't find it in the docs for the driver? Is it an option the driver is expecting to receive from the application?
drphilth
Postby drphilth » Sun Oct 22, 2017 2:45 am
OK, I've done some more debugging.
With my old, working driver, I generated an initial scan file from w_scan. I noticed that the DVBT2 channels didn't have a valid bandwidth set, so I manually edited it to be 8MHZ.
[CHANNEL]
   DELIVERY_SYSTEM = DVBT
   FREQUENCY = 482000000
   BANDWIDTH_HZ = 8000000
   CODE_RATE_HP = 3/4
   CODE_RATE_LP = NONE
   MODULATION = QAM/64
   TRANSMISSION_MODE = 8K
   GUARD_INTERVAL = 1/32
   HIERARCHY = NONE
   INVERSION = AUTO
[CHANNEL]
   FREQUENCY = 490000000
   CODE_RATE_HP = 2/3
   CODE_RATE_LP = NONE
   MODULATION = QAM/64
   HIERARCHY = NONE
   INVERSION = AUTO
[CHANNEL]
   FREQUENCY = 514000000
   CODE_RATE_HP = 2/3
   CODE_RATE_LP = NONE
   MODULATION = QAM/64
   HIERARCHY = NONE
   INVERSION = AUTO
[CHANNEL]
   DELIVERY_SYSTEM = DVBT2
   FREQUENCY = 546000000
   CODE_RATE_HP = NONE
   CODE_RATE_LP = NONE
   MODULATION = QAM/AUTO
   TRANSMISSION_MODE = 2K
   HIERARCHY = NONE
   STREAM_ID = 4294967295
   INVERSION = AUTO
[CHANNEL]
   FREQUENCY = 506000000
   CODE_RATE_HP = 3/4
   CODE_RATE_LP = NONE
   MODULATION = QAM/64
   HIERARCHY = NONE
   INVERSION = AUTO
[CHANNEL]
   FREQUENCY = 530000000
   CODE_RATE_HP = 3/4
   CODE_RATE_LP = NONE
   MODULATION = QAM/64
   HIERARCHY = NONE
   INVERSION = AUTO
[CHANNEL]
   FREQUENCY = 570000000
   CODE_RATE_HP = NONE
   CODE_RATE_LP = NONE
   HIERARCHY = NONE
   INVERSION = AUTO
[CHANNEL]
   FREQUENCY = 586000000
   CODE_RATE_HP = NONE
   CODE_RATE_LP = NONE
   HIERARCHY = NONE
   INVERSION = AUTO
[CHANNEL]
   FREQUENCY = 537833000
   CODE_RATE_HP = 3/4
   CODE_RATE_LP = NONE
   MODULATION = QPSK
   HIERARCHY = NONE
   INVERSION = AUTO
I was able to successfully use this file with my old (ljalves) driver to generate a channels file with dvbv5-scan. Having generated this file, I was able to tune channels with the old driver using dvbv5-zap
I then compiled and installed the more up to date tbs open source driver. I cannot tune channels with dvbv5-zap. When I try to run a channel scan I get this output:
$ dvbv5-scan initial_data_v5.conf
Cannot calc frequency shift. Either bandwidth/symbol-rate is unavailable (yet).
Scanning frequency #1 482000000
Lock   (0x1f) C/N= 21.75dB UCB= 0 postBER= 11.2x10^-3
ERROR    dvb_read_sections: no data read on section filter
ERROR    error while waiting for PAT table
Scanning frequency #2 490000000
Lock   (0x1f) Signal= -52.00dBm C/N= 29.00dB UCB= 0 postBER= 1.00
Scanning frequency #3 514000000
Lock   (0x1f) Signal= -52.00dBm C/N= 28.50dB UCB= 0 postBER= 1.00
Scanning frequency #4 546000000
Lock   (0x1f) Signal= -52.00dBm C/N= 32.25dB UCB= 0 postBER= 1.00
^Cphilip@soundwave:~$ sudo dvbv5-scan initial_data_v5.conf
ERROR    FE_READ_STATUS: Remote I/O error
ERROR: dvb_fe_get_stats failed (Remote I/O error)
ERROR    Error: no adapter status
Lock   (0x1f) C/N= 30.25dB UCB= 0 postBER= 25.5x10^-3
Lock   (0x1f) Signal= -52.00dBm C/N= 22.00dB UCB= 0 postBER= 1.00
Lock   (0x1f) Signal= -52.00dBm C/N= 21.25dB UCB= 0 postBER= 1.00
Scanning frequency #5 506000000
Lock   (0x1f) Signal= -50.00dBm C/N= 27.25dB UCB= 0 postBER= 1.00
Scanning frequency #6 530000000
Lock   (0x1f) Signal= -53.00dBm C/N= 21.75dB UCB= 0 postBER= 1.00
Lock   (0x1f) C/N= 22.00dB UCB= 0 postBER= 45.3x10^-3
Lock   (0x1f) Signal= -52.00dBm C/N= 28.25dB UCB= 0 postBER= 1.00
Lock   (0x1f) Signal= -50.00dBm C/N= 27.50dB UCB= 0 postBER= 1.00
^Cphilip@soundwave:~$ dvbv5-scan initial_data_v5.conf
Lock   (0x1f) C/N= 21.25dB UCB= 0 postBER= 60.6x10^-3
Lock   (0x1f) Signal= -52.00dBm C/N= 21.75dB UCB= 0 postBER= 1.00
Lock   (0x1f) Signal= -50.00dBm C/N= 27.00dB UCB= 0 postBER= 1.00
Lock   (0x1f) Signal= -52.00dBm C/N= 21.50dB UCB= 0 postBER= 1.00
Scanning frequency #7 570000000
Lock   (0x1f) Signal= -52.00dBm C/N= 28.75dB UCB= 0 postBER= 1.00
Scanning frequency #8 586000000
Lock   (0x1f) Signal= -60.00dBm C/N= 30.75dB UCB= 0 postBER= 1.00
Scanning frequency #9 537833000
Lock   (0x1f) Signal= -56.00dBm C/N= 19.25dB UCB= 0 postBER= 1.00
Any ideas on where to go from here? As far as I can see, I am correctly specifying the DVBT / DVBT2 type and I have set the bandwidth correctly.
drphilth
Postby drphilth » Sun Oct 22, 2017 5:52 am
Here's the working version of the drivers:
https://www.dropbox.com/s/o9ohj3ljeke9u ... g.zip?dl=0
Still compiling against kernel 4.4.0-97-generic on ubuntu server. I have no idea if it will compile against anything newer than that.
drphilth
Postby drphilth » Sun Oct 22, 2017 3:45 pm
dvbv5-scan output from the working version of the drivers. I've removed the full list of services, for brevity:
Lock   (0x1f) C/N= 23.00dB
Service E4+1, provider (null): digital television
WARNING  Channel 697 (service ID 24500) not found on PMT. Skipping it.
Service BBC ONE Lon, provider (null): digital television
Service ITV, provider (null): digital television
Service BBC TWO HD, provider (null): reserved
Lock   (0x1f) Signal= -51.00dBm C/N= 27.50dB
Service QVC, provider (null): digital television
Lock   (0x1f) Signal= -49.00dBm C/N= 28.25dB
Service 4Music, provider (null): digital television
Lock   (0x1f) Signal= -53.00dBm C/N= 30.75dB
Service Al Jazeera Eng HD, provider (null): reserved
Lock   (0x1f) Signal= -60.00dBm C/N= 31.00dB
Service QVC HD, provider (null): reserved
Lock   (0x1f) Signal= -55.00dBm C/N= 18.75dB
Service London Live, provider (null): digital television
drphilth
