How fully to reinstall MOI-PRO AMD
Postby fr34k » Sun Oct 08, 2017 1:56 am
I have tried to reinstall my MOI-PRO AMD, And after it's finished on start I can see my old installation and new one.
My question is how to reinstall it, and when is finished at there is only one option for start and it's newly/fresh installed.
Regards,
fr34k
fr34k
Re: How fully to reinstall MOI-PRO AMD
Postby steven » Mon Oct 09, 2017 10:30 am
Postby skilite » Fri May 03, 2019 9:15 pm
j'ai suivi ce guide et il ne marche pas au demarrage avec la clè usb il ne recoonait pas, rien afiché à l'ecran
skilite
Postby steven » Thu May 09, 2019 11:57 am
skilite Wrote:j'ai suivi ce guide et il ne marche pas au demarrage avec la clè usb il ne recoonait pas, rien afiché à l'ecran
if you have issue you can send detail information to our support
thanks
kind regards
Postby skilite » Thu Sep 05, 2019 8:03 pm
j'avais juste oublié de tester le port vga
skilite
Return to MOI Pro - AMD
