blindscanning issues
Postby tasoss » Sun Sep 10, 2017 4:15 am
Hello.
I have tried the following scenarios(all on the same satellite)
1)Using tbs 6903
adapter 0 -> bscan2
adapter 1 ->bscan
2)Using tbs 6908
adapter 0 -> bscan2
adapter 1 ->bscan
After a few hours bscan2 can't find any transponders.But bscan1 continues to work correctly.
If i stop bscan2 and restart it , it will start working again.
If i run bscan2 alone then i haven't seen any problems.
Do you have any suggestions?
Thank you very much!
tasoss
Re: blindscanning issues
Postby steven » Mon Sep 11, 2017 11:31 am
Do you mean you always on scan with TBS BSScan tools ? after a lot of times scan it stop working ?
Postby tasoss » Mon Sep 11, 2017 2:45 pm
Hello.
I should have mentioned that i use crazycat's blindscan with loop=1.
tasoss
Postby steven » Mon Sep 11, 2017 3:06 pm
Hi tasoss
Thanks for your update : )
Maybe write an script let crazyscan auto closed and running every 1 hour
Postby tasoss » Wed Sep 13, 2017 5:45 am
I agree although this is a dirty solution :)
Anyway thanks for answering!
tasoss
