Diseqc
Diseqc
Postby SteveHill » Tue Aug 22, 2017 2:32 pm
My current setup is multiple set top boxes connected to 64 LNBs
Each set top box is able to address 64 LNBs using Diseqc 1.1
Uncommitted - Diseqc 1.1 - Input 1..16
Committed - Diseqc 1.0 - Input 1..4 (A..D)
Tone
I would like to add the MOI-V box to the setup and connect the multi-lnb feed(s)
Does the PBS6909 DVB-S2 8 Tuner Card support passing on Diseqc 1.0 and Diseqc 1.1 commands?
How does the PBS6909 use it’s internal multiswitch? Does it use Diseqc?
Is the PBS6908 DVB-S2 4 Tuner a better option?
Will there be a 8 Tuner supporting 16/32 APSK?
Steve
SteveHill
