TBS 6902 not detected after reboot
Postby Mark83827 » Thu Aug 17, 2017 6:11 pm
Hi, no response from support@tbsdtv.com for two weeks so posting here.
I have a TBS 6902 that's failing to be detected following driver compilation and reboot.
"uname -a" output:
Linux freyr 4.4.0-77-generic #98-Ubuntu SMP Wed Apr 26 08:34:02 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
"cat /etc/issue":
Ubuntu 16.04.3 LTS \n \l
(Actual installation is MythBuntu back-end only)
Followed the "TBS User Guide". (Copy paste bug in my PDF viewer so typed in manually)
The card is alive:
root@freyr:~/results-failure# lspci -vvv |grep 6902
Subsystem: Device 6902:0002
Found problem here:
root@freyr:~/results-failure# git clone --depth=1 https://github.com/linux_media.git -b latest ./media
Cloning into './media'...
remote: Not Found
fatal: repository 'https://github.com/linux_media.git/' not found
I then downloaded the driver by the product from your website (tbs-linux-drivers_v170330.zip)
Got it to compile but after reboot dmesg|grep frontend matched nothing
Then tried following instructions from this post by "steven":
viewtopic.php?f=183&t=10244#p37627
Same result - nothing in dmesg after reboot
Logs attached. Thanks.
Mark83827
Re: TBS 6902 not detected after reboot
Postby steven » Fri Aug 18, 2017 9:53 am
Can you have a try change the PCI-E slot and connect the extra power for your TBS6902 ?
Check whether will be ok for the driver you can use this one :
#wget http://www.tbsdtv.com/download/document/linux/media_build-2017-0726.tar.bz2
#tar jxvf media_build-2017-0726.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby Mark83827 » Sun Aug 20, 2017 5:28 pm
I swapped the card into the other pcie slot and removed the other card I have (a usb controller card).
Then made sure the power supply was working (tested 12v) and checked it was plugged into the card.
Followed your install instructions
Card showing from lspci:
01:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
but still no output from dmesg|grep frontend
Have attached the output from install.sh - plenty of warnings even though it completed. Perhaps some of the warnings need solving?
media_build.log.bz2
(17.38 KiB) Downloaded 490 times
Mark83827
Postby Mark83827 » Fri Aug 25, 2017 6:53 pm
Nearly a week and no response. Is it time to request a refund?
Mark83827
Postby crazycat » Sun Aug 27, 2017 8:47 am
Mark83827 Wrote:Found problem here:
remote: Not Found
wrong url, must be https://github.com/tbsdtv/linux_media.git
Postby Mark83827 » Thu Aug 31, 2017 10:10 pm
That worked, then running make -j4:
/root/tbsdriver/media_build/v4l/dvb_demux.c:23:32: fatal error: linux/sched/signal.h: No such file or directory
compilation terminated.
Mark83827
