Tbs5927 fan control
Tbs5927 fan control
Postby Ericed1965 » Mon Jul 31, 2017 2:49 pm
I received my tbs5927 and installed driver on ubuntu 17, it is working fine.
However, the fan is blowing fast and noisy, is there a way to diminish that noise?
I saw in the windows section a recommendation to disconnect the fan, i find it a bit weird as i read at many places that the tbs5925 was a bit hot. So i would rather go for diminushing the speed (by 2?). For this effect, what resistor shall i insert in the power supply line of the fan?
Thanks.
Ericed1965
Re: Tbs5927 fan control
Postby Ericed1965 » Wed Aug 02, 2017 10:26 pm
Is there anybody reading answering ng questions in this forum?
Ericed1965
Postby steven » Thu Aug 03, 2017 2:48 pm
Hi Ericed1965
You can have a try add one resistor to the power supply line of the fan ,what resistor you can try with a smaller first if you still
think it is fast you can add more bigger then find the right one you want to use ;)
Postby Ericed1965 » Thu Aug 03, 2017 3:02 pm
Thanks for your reply. Do you by any chance could find out the resistance of the fan? It would help me to find out what resistance to add.
I suspect it is a 12v fan, but how many amps? (I can see the tacho is not connected, which is normal).
I am thinking to place a small potentiometer like that I would be able to adjust the speed better, however to get the right portentiometer I need some more information about the fan spec. Can you ask your engineers the fan spec please?
Thanks for your answer.
Ericed1965
Postby steven » Thu Aug 03, 2017 3:21 pm
you are welcome .
It is about 12V and 180mA .
Postby Ericed1965 » Thu Aug 03, 2017 4:02 pm
Ericed1965
Postby Ericed1965 » Tue Aug 08, 2017 1:05 am
Bourns 3006P-1-201LF does the job, silence is back, with a gentle air flow in the box.
Ericed1965
