Linux: cx231xx #0: UsbInterface::sendCommand, failed with st
Postby imsadi » Mon Jul 31, 2017 2:08 pm
HI,
running a linux vdr with easyvdr 3.0. Compiling and installing works so far. Both tuner recognized but after an approx. an hour the systems freezes with. Maybe i should mention that in the ci slot is an alphacrypt module.
cx231xx #0: UsbInterface::sendCommand, failed with status --19
Kernel:
Linux 4.4.0-45-generic
lsusb:
lsusb
Bus 002 Device 002: ID 734c:5990 TBS Technologies China
Bus 001 Device 002: ID 14f7:0500 TechniSat Digital GmbH DVB-PC TV Star HD
dmesg | grep tbs
 dmesg | grep tbs
[    8.780513] tbscxci: Initializing TBS CX CI#0 slot
[    8.790851] tbscxci: Adapter 1 CI slot initialized
[    9.381146] tbscxci: Initializing TBS CX CI#1 slot
[    9.383007] tbscxci: Adapter 2 CI slot initialized
[    9.383396] tbscxci: Adapter 2 CI slot disabled
[   15.436401] tbscxci: Adapter 1 CI slot enabled
[   18.174677] tbscxci: Adapter 1 CI slot disabled
[   19.816639] tbscxci: Adapter 1 CI slot enabled
 dmesg | grep frontend
[    5.559586] DVB: registering adapter 0 frontend 0 (Technisat SkyStar USB HD (                                            DVB-S/S2))...
[    8.775763] DVB: registering adapter 1 frontend 0 (TurboSight TBS 5990FE DVBS                                            /S2 frontend)...
[    9.380538] DVB: registering adapter 2 frontend 0 (TurboSight TBS 5990FE DVBS
imsadi
Re: Linux: cx231xx #0: UsbInterface::sendCommand, failed wit
Postby steven » Mon Jul 31, 2017 2:32 pm
Please have a try with dvblast check whether is ok
Postby imsadi » Mon Jul 31, 2017 2:42 pm
i could do that, but it´s not my intention, because i want to use all these improvements of vdr :-)
Never the less, i will give it a try, if it helps you.
Best regards
imsadi
