TBS6910 SMiT CAM with iredeto smart card
Postby Avem » Tue Jul 25, 2017 8:05 pm
Hello TBS Team,
We are using TBS6910 and inserted SMIT CAM with iredeto smart card, we are trying to stream using dvblast but we are getting error messages as mentioned below. The iredeto smart card working with other IRDs.
Could you please help us in resolving this issue with TBS6910 tuner card.
Please let us know whether TBS6910 supports SMIT CAM or not ? if not supports which CAM well supported by TBS6910 ?
============== LOG============================================
debug: CI slot 0 is active
debug: opening ResourceManager session (1)
debug: opening ApplicationInformation session (2)
info: CAM: Irdeto Access, 01, CAFE, BABE
warning: TS discontinuity on pid 352 expected_cc 1 got 13 (H.262/13818-2 video (MPEG-2) or 11172-2 constrained video, sid 1)
warning: TS discontinuity on pid 288 expected_cc 7 got 14 (13818-3 audio (MPEG-2), sid 1)
warning: TS discontinuity on pid 293 expected_cc 13 got 1 (PMT, sid 1)
warning: TS discontinuity on pid 35 expected_cc 10 got 14 (PMT, sid 15)
warning: TS discontinuity on pid 37 expected_cc 10 got 14 (PMT, sid 17)
warning: TS discontinuity on pid 549 expected_cc 9 got 13 (PMT, sid 2)
warning: TS discontinuity on pid 2853 expected_cc 10 got 14 (PMT, sid 11)
warning: TS discontinuity on pid 805 expected_cc 10 got 14 (PMT, sid 3)
warning: TS discontinuity on pid 1573 expected_cc 10 got 14 (PMT, sid 6)
warning: TS discontinuity on pid 1829 expected_cc 9 got 13 (PMT, sid 7)
warning: TS discontinuity on pid 3109 expected_cc 10 got 14 (PMT, sid 12)
warning: TS discontinuity on pid 3365 expected_cc 10 got 14 (PMT, sid 13)
warning: TS discontinuity on pid 34 expected_cc 10 got 14 (PMT, sid 14)
warning: TS discontinuity on pid 2341 expected_cc 10 got 14 (PMT, sid 9)
warning: TS discontinuity on pid 0 expected_cc 0 got 5 (PAT, sid 0)
warning: TS discontinuity on pid 16 expected_cc 0 got 5 (NIT, sid 0)
warning: TS discontinuity on pid 1 expected_cc 15 got 4 (CAT, sid 0)
warning: TS discontinuity on pid 1061 expected_cc 10 got 14 (PMT, sid 4)
warning: TS discontinuity on pid 36 expected_cc 10 got 14 (PMT, sid 16)
warning: TS discontinuity on pid 2146 expected_cc 10 got 14 (PMT, sid 8)
warning: TS discontinuity on pid 1317 expected_cc 10 got 14 (PMT, sid 5)
warning: TS discontinuity on pid 2597 expected_cc 10 got 14 (PMT, sid 10)
warning: TS discontinuity on pid 17 expected_cc 8 got 0 (SDT, sid 0)
warning: TS discontinuity on pid 2048 expected_cc 7 got 14 (EMM, sid 0)
warning: TS discontinuity on pid 20 expected_cc 13 got 1 (TDT/TOT, sid 0)
debug: opening ConditionalAccess session (3)
debug: CA system IDs supported by the application :
debug: - 0xfff
debug: adding first CAPMT for SID 1 on session 3
warning: no compatible scrambling system for SID 1 on session 3
====== END OF LOG ========================
Avem
Re: TBS6910 SMiT CAM with iredeto smart card
Postby steven » Wed Jul 26, 2017 9:46 am
HI Avem
Which driver you are using ?
and what about the transponder information ? which satellite ? and do you have tested other transponder is it ok ?
Postby Avem » Wed Jul 26, 2017 4:43 pm
Dear steven,
We are using TBS linux drivers as mentioned in tbs6910 user guide. The driver code fetched from "https://github.com/tbsdtv/media_build and followed the steps mentioned in the guide.
We are trying to tune to frequency 40005, pol:H, srate:26666. This is INSAT 4A satellite. Tested with FTA channels with other transponders all are working fine.
This problem is occuring with only tbs6910, tested the above mentioned scrambled channel with other commercial irds with same CAM working fine.
Please help us on this.
Thanks,
Avem
Avem
