TBS5990 channels not work
Postby cathod » Wed Jul 19, 2017 6:13 pm
Hi there ..
I have TBS5990 , My operating system is windows 10 x64
After windows 10 updated , No channel work in this device.
The TBS5990 driver is install and updated , But no channle work at all.
I unstall and reinstall the driver many tims , Still no channel work.
Please need help.
cathod
Re: TBS5990 channels not work
Postby daowei » Wed Jul 26, 2017 10:20 am
This tbs5990 is working, no problem. right? only change to a new windows OS win10 64-bit, then can't find any channels at more?
Does the driver download from "https://www.tbsiptv.com/download/tbs5990/tbs5990-win10-driver_v1.0.0.6.zip" ?
Did you update another OS like win7 to win10 64-bit OS directly? maybe you can try reinstall a new win10 64-bit OS in a clear image.
Postby cathod » Thu Jul 27, 2017 7:31 pm
TBS9550 was work with windows 10 X64 perfect and with driver_v1.0.0.6 , After windows updated no channel work at all , i unstall and download the driver from the TBSdTV site again and reinstall the driver many times still no channel word
cathod
Postby steven » Fri Jul 28, 2017 3:45 pm
Please have a check
security update KB4013429 cause issue
after update
good news! There was another, the latest, Windows update (KB4015217) which I have just installed which apparently repaired the problems with the previous update.
