DVBlast Tunner status web interface
Postby ahmedramze » Tue Jul 18, 2017 7:26 am
Hello
I just complete php page for tunner signal SNR and signal strength for running dvblast , need to add -r /tmp/1.sock to dvlast command for example
dvblast -a 1 -e -Y -W -f  12340000  -s 27500000 -v 18 -m psk_8  -r /tmp/4.sock -c /root/dvblast_3.conf
the code for page to read from soct that made on /tmp folder or elese
im try to add code but form limit only 10000 char and also not accept php or txt or any source files will split it into two post
TBS also please add it to your web interface for all products also please add ( -Y and -W and -e to pass the EPG and network information for channels like name etc)
and the result for 4 tunner or more you can copy and past just change scoket number.
table align="center" border=1>
  <tr>
    <th>
<h1>< Tunner LNB-0 Status ></h1>
<B>Signal SNR:</B>
<style>
#meter_item
    width: 100%;
#scale {
    display: table;
    width: 100%;
    padding: 0px 0px 0px 0px;
    margin: 2px 0px 10px 0px;
    border: 0px 0px 0px 0px;
    text-align: center;
#scale li {
    width: 10%;
    display: table-cell;
    white-space: nowrap;
</style>
<div style="width: 100%">
    <meter id="meter_item" min="0" value=<?php $sig = shell_exec('dvblastctl -r  /tmp/1.sock fe_status | grep -i "snr"| cut -d\: -f2 | sed -e
"s| ||g" '); $sig = intval ($sig / 655,2); echo $sig;?> max="100" ></meter>
    <ul id="scale">
    <li style="width: 5%"><span></span></li>
    <li><span id="scale">10</span></li>
    <li><span id="scale">20</span></li>
    <li><span id="scale">30</span></li>
    <li><span id="scale">40</span></li>
    <li><span id="scale">50</span></li>
    <li><span id="scale">60</span></li>
    <li><span id="scale">70</span></li>
    <li><span id="scale">80</span></li>
    <li><span id="scale">90</span></li>
    <li style="width: 10%"><span id="scale"></span></li>
    </ul>
</div>
<B>Signal Strength:</B>
<style>
#meter_item
    width: 100%;
#scale {
    display: table;
    width: 100%;
    text-align: center;
#scale li {
    width: 10%;
</style>
    <meter id="meter_item" min="0" value=<?php $sig = shell_exec('dvblastctl -r  /tmp/1.sock fe_status | grep -i "strength"| cut -d\: -f2 | se
d -e "s| ||g" '); $sig = intval ($sig / 655,2); echo $sig;?> max="100" ></meter>
    <ul id="scale">
    </ul>
</div>
</th>
<th>
<h1>< Tunner LNB-1 Status ></h1>
<B>Signal SNR:</B>
<style>
#meter_item
    width: 100%;
#scale {
    display: table;
    width: 100%;
    text-align: center;
#scale li {
    width: 10%;
</style>
    <meter id="meter_item" min="0" value=<?php $sig = shell_exec('dvblastctl -r  /tmp/2.sock fe_status | grep -i "snr"| cut -d\: -f2 | sed -e
    <ul id="scale">
    </ul>
</div>
<style>
#meter_item
    width: 100%;
#scale {
    display: table;
    width: 100%;
    text-align: center;
#scale li {
    width: 10%;
</style>
    <meter id="meter_item" min="0" value=<?php $sig = shell_exec('dvblastctl -r  /tmp/2.sock fe_status | grep -i "strength"| cut -d\: -f2 | se
    <ul id="scale">
    </ul>
</div>
</th>
</tr>
 <tr>
<td>
<h1>< Tunner LNB-2 Status ></h1>
<B>Signal SNR:</B>
<style>
#meter_item
    width: 100%;
#scale {
    display: table;
    width: 100%;
    text-align: center;
#scale li {
    width: 10%;
</style>
ahmedramze
Re: DVBlast Tunner status web interface
Postby ahmedramze » Tue Jul 18, 2017 7:28 am
2nd part
    <meter id="meter_item" min="0" value=<?php $sig = shell_exec('dvblastctl -r  /tmp/3.sock fe_status | grep -i "snr"| cut -d\: -f2 | sed -e
    <ul id="scale">
    </ul>
</div>
<style>
#meter_item
    width: 100%;
#scale {
    display: table;
    width: 100%;
    text-align: center;
#scale li {
    width: 10%;
</style>
    <meter id="meter_item" min="0" value=<?php $sig = shell_exec('dvblastctl -r  /tmp/3.sock fe_status | grep -i "strength"| cut -d\: -f2 | se
    <ul id="scale">
    </ul>
</div>
</td>
<td>
<h1>< Tunner LNB-3 Status ></h1>
<B>Signal SNR:</B>
<style>
#meter_item
    width: 100%;
#scale {
    display: table;
    width: 100%;
    text-align: center;
#scale li {
    width: 10%;
</style>
    <meter id="meter_item" min="0" value=<?php $sig = shell_exec('dvblastctl -r  /tmp/4.sock fe_status | grep -i "snr"| cut -d\: -f2 | sed -e
    <ul id="scale">
    </ul>
</div>
<style>
#meter_item
    width: 100%;
#scale {
    display: table;
    width: 100%;
    text-align: center;
#scale li {
    width: 10%;
</style>
    <meter id="meter_item" min="0" value=<?php $sig = shell_exec('dvblastctl -r  /tmp/4.sock fe_status | grep -i "strength"| cut -d\: -f2 | se
    <ul id="scale">
    </ul>
</div>
</td>
  </tr>
</table>
ahmedramze
Postby steven » Fri Dec 08, 2017 10:35 am
Hi ahmedramze
very nice thanks for your share ; )
Postby sajjads24 » Thu Jun 28, 2018 6:30 am
hi
please add this app to fedora or rpmfusion repository for install on fedora 28 ?
please add to repo or make rpm package ?
My Card = TBS6983
sajjads24
Postby AraldoJanes » Sat May 04, 2019 1:36 am
Hi....this will install a few binaries and scripts in/usr/local/bin and create the folder /usr/local/share/rtranscode containing a configuration file and and a default (empty) channel database. An existing channel database (from rtranscode 3) will not be overwritten and you can continue to use it, although the database format has slightly changed.
pcb manufacturing and assembly
AraldoJanes
Return to News
