No Signal on HD channel under win7 Media Centre
Postby pcrunsdeep » Thu Dec 01, 2011 4:22 am
Hi, I have just purchased and installed this card into my HTPC running windows 7 Enterprise X64.
This setup has been running for about a year now with other cards but they were not able to pick up Freesat HD,
so I thought I would try this card.
So Far it can only see BBC HD channel and then only gives No Signal, any help in
a. setup for the other Freesat HD channels
b. actually recieving signal
Thanks in advance
pcrunsdeep
Re: No Signal on HD channel under win7 Media Centre
Postby smile » Thu Dec 01, 2011 9:12 am
Hi pcrunsdeep
would you mind try to scan the HD channel in other player, such as DVB Dream,TBSview? if it is ok,I think the problem occur in the WIN 7 Media Center.
and you can try to updata the channel list in some way.
thanks
smile
