Cannot tune DVB-S2 nor szap
Postby CKDewey » Fri Feb 18, 2011 8:55 pm
I can tune DVB-S but not S2 under tvheadend with the latest drivers from your web site using Ubuntu server 10.10 amd64 with kernel 2.6.35-22.
I've disabled tvheadend at boot but I still cannot scan using szap-s2 at all.
I'm pointed to Palapa-D at 113E.
Here is my szap config:
SPC:4080:h:0:28125:515:653:4
ALJ:4100:v:0:30000:4466:4467:19
My command:
sudo ./szap-s2 -c spacetoon.data -a 1 -p -r -S 0 -M 2 -C 34 "SPC"
and the output:
reading channels from file 'spacetoon.data'
zapping to 1 'SPC':
sat 0, frequency 4080 MHz H, symbolrate 28125000, coderate 3/4, rolloff 0.35
vpid 0x0203, apid 0x028d, sid 0x0004
using '/dev/dvb/adapter1/frontend0' and '/dev/dvb/adapter1/demux0'
FE_SET_PROPERTY failed: Invalid argument
It hangs at this point, and I must ctrl-C to exit. I get the same result with 'ALJ' which is S2.
In tvheadend I can tune and play the first program, but the mux for the second program shows no signal. Both work fine on my set-top box.
I've also tried the w_scan utility and get 'no signal.' Your help is greatly appreciated.
Regards,
CK
CKDewey
Re: Cannot tune DVB-S2 nor szap
Postby CKDewey » Sat Feb 19, 2011 5:21 pm
Now when I try to build the drivers under the latest Ubuntu 10.10 generic kernel (2.6.35-25-generic) I get:
WARNING: could not find /home/videobox/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/.tbs6980ctrl.o.cmd for /home/videobox/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/tbs6980ctrl.o
WARNING: could not find /home/videobox/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/.tbs6980fe_driver.o.cmd for /home/videobox/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/tbs6980fe_driver.o
WARNING: could not find /home/videobox/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/.tbs6981fe_driver.o.cmd for /home/videobox/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/tbs6981fe_driver.o
CK
CKDewey
Postby cody » Sun Feb 20, 2011 8:51 pm
i believe i did answer to you few days ago via e-mail, because it seems to me you sent also e-mail to out support addresses. please, feel free to choose continue the discussion here or via e-mail. thank you!
Postby CKDewey » Mon Feb 21, 2011 12:09 am
Hi Cody,
I did not see your email, can you post the reply here?
Thanks,
CK
CKDewey
Postby cody » Wed Feb 23, 2011 4:07 am
hi, of course, maybe, you're no the same customer, but asking similar question(s), here is what i replied:
please, give me 'szap-s2' command line and output that you use when you try
to lock those DVB-S2 transponders. also, one mistake that i see right away
is that you use 'szap-s2' without "-l" (lower case "L") switch to tell your
LNB type to 'szap-s2' and that's why you get error:
> couldn't find pmt-pid for sid 18b53
in fact the lock you got with 'szap-s2' is not acquired by 'szap-s2',
because of the above error, but some lock left from previous use of the card. if
you type 'dmesg | grep tbs6981fe' and/or check other debug messages with
'dmesg', i'm sure there will be error message that the frequency is out of
range. anyway, let's first check the output of 'szap-s2' when you try to
lock those DVB-S2 transponders and then proceed from there.
thank you,
Postby CKDewey » Wed Feb 23, 2011 2:18 pm
Hi Cody,
My szap config file looks like this:
ASN:4100:v:0:30000:4466:4467:19
Here is what I get with the 'S' transponder when I add the '-l' command:
videobox@videobox:~/linux-s2api-tbs6980-1_20101024/szap-s2$ ./szap-s2 -x -c spacetoon.data -l 5150,5150 -a 1 -p -r -S 0 -M 2 -C 34 "SPC"
zapping to 1 'SPC':
status 1f | signal bf2e | snr 8888 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
However the 'S2' transponder on the same satellite does not work, it just hangs. The feed works fine on my set top box:
videobox@videobox:~/linux-s2api-tbs6980-1_20101024/szap-s2$ ./szap-s2 -x -c spacetoon.data -l 5150,5150 -a 1 -p -r -S 1 -M 5 -C 56 "ASN"
zapping to 2 'ASN':
delivery DVB-S2, modulation 8PSK
sat 0, frequency 4100 MHz V, symbolrate 30000000, coderate 5/6, rolloff 0.35
vpid 0x1172, apid 0x1173, sid 0x0013
I hope you can advise further on how I might get this working.
Thanks,
CK
CKDewey
Postby CKDewey » Thu Feb 24, 2011 6:54 pm
Cody,
Can you tell me which Linux distribution is known to work with your drivers? I have been using Ubuntu for years but I will happily re-install with Debian or any other in order to solve the problem quickly.
Thanks,
CK
CKDewey
Postby cody » Fri Feb 25, 2011 9:39 pm
hi, our Linux development and testing is done exactly in Ubuntu. we saw you mailed us and let's sone some live debugging of the problem as you suggested. we're going to contact you via Skype.
