TBS-5520SE /dev/dvb/adapter0 gone missing
Postby maff » Sat Jun 10, 2017 3:29 am
Had a TBS-5520SE for a couple of weeks, and other than a little teething trouble with Mythtv assuming there is a a demux1 if you use frontend1 it's been working a really well!
However last night I rebooted and /dev/dvb/adapter0 has vanished.
Can someone give me some pointers as to what to check?
I'm using the latest drivers from https://github.com/tbsdtv/linux_media/wiki
Which compiled and installed happily.
lsusb:
Bus 001 Device 002: ID 734c:5521 TBS Technologies China
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
lsdvb:
                Version: 0.0.4
                Copyright (C) Manu Abraham
ERROR: Opening /sys/class/dvb directory
and indeed /dev/dvb does not exist anymore.
dmesg | grep usb:
[    0.209294] usbcore: registered new interface driver usbfs
[    0.209294] usbcore: registered new interface driver hub
[    0.209294] usbcore: registered new device driver usb
[    0.964076] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.964079] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.964081] usb usb1: Product: EHCI Host Controller
[    0.964083] usb usb1: Manufacturer: Linux 4.4.0-79-generic ehci_hcd
[    0.964084] usb usb1: SerialNumber: 0000:00:02.1
[    1.022050] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.022052] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.022054] usb usb2: Product: OHCI PCI host controller
[    1.022056] usb usb2: Manufacturer: Linux 4.4.0-79-generic ohci_hcd
[    1.022058] usb usb2: SerialNumber: 0000:00:02.0
[    1.276019] usb 1-4: new high-speed USB device number 2 using ehci-pci
[    1.408361] usb 1-4: New USB device found, idVendor=734c, idProduct=5521
[    1.408364] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
I've tried different usb ports... but no luck.
Any help much appreciated!
maff
Re: TBS-5520SE /dev/dvb/adapter0 gone missing
Postby maff » Sun Jun 11, 2017 5:47 pm
My bad, had updated from \
4.4.0-78-generic
to
4.4.0-79-generic
and had been running the instructions from here: https://github.com/tbsdtv/linux_media/wiki from the section: Upgrading sources and re-installing. But that just kept building new 4.4.0-78-generic driver versions.
Deleting media & media_build and re-running the Downloading and building instructions from scratch fixed the problem (drivers for 4.4.0-79-generic).
You live and learn.
:mrgreen:
maff
Postby serkanguzel » Sun Jun 11, 2017 6:36 pm
@maff,
Thank you effort.
Is this study, for TBS5520SE driver file ? And is it make BlindScan ?
I installed the crazycat's blindscan driver. And it looks like in the picture;
That is, when the 5520SE is connected to the USB port, an "unknown device" warning is issued.
But the TV card is working normally.
Do you have any idea about this problem ? ( unknown device )
serkanguzel
Postby maff » Sun Jun 11, 2017 8:24 pm
No sorry, I have not used the TBS-5520SE with Windows, only linux.
maff
Postby triovi » Thu Jun 15, 2017 3:58 am
serkanguzel Wrote:@maff,
Thank you effort.
serkanguzel, did you install the last TBS drivers? https://www.tbsiptv.com/index.php?route ... vers&id=43 V1.0.0.5.
It just appear.
triovi
