Installing Drivers
Installing Drivers
Postby HaggisUK » Tue Nov 29, 2011 9:46 pm
Hello all.
I've downloaded the latest drivers for my TBS 8920 v1.0.6.1 for window 7 64.
After installing and then checking device manager....It tells me under TBS 8920 DVBS that 1.0.6.0 is installed....why is it not 1.0.6.1?
Then checking TBS 8920 TS capture....under "general" it says "No drivers are installed for this device."....but then under the driver tab..it says 1.0.6.0 is installed.
Can someone please tell me if these results are correct or if I'm doing something wrong when installing the 1.0.6.1 drivers.
Please see images.
Thank you for any help provided.
HaggisUK
Re: Installing Drivers
Postby smile » Fri Dec 02, 2011 3:47 pm
Hi HaggisUK
The driver version really is v1.0.6.1,but we forgot to change the version value.thanks for you find out this mistake.we will change the value in the lastest version.
thanks.
smile
Postby HaggisUK » Fri Dec 02, 2011 7:58 pm
Hello Smile.
Thanks for the reply.
should I reinstall v1.0.6.1 now? or is a new driver going to be issued in the near future?
Why does device manager report "No drivers are installed for this device."?...the TBS 8920 TS capture driver (image 2)
Thanks for your help
HaggisUK
Postby smile » Sat Dec 03, 2011 11:53 am
Hi HaggisUK
This is download link http://hotfile.com/dl/136596103/5ecaac5/TBS8920setup_win7.rar.html.we change the version value.and the TS capture don't need the driver.
smile
Postby HaggisUK » Sat Dec 03, 2011 6:01 pm
Thanks Smile....Device manager is now reporting 1.0.6.1 installed.
Problem solved.
HaggisUK
Postby artikal » Tue Nov 13, 2012 5:00 pm
I Have This Problem Too ! What am i must do ?
my windows is : 7 64 bit
artikal
Postby artikal » Tue Nov 13, 2012 6:23 pm
in dvbdream says : no signal !
artikal
Postby smile » Wed Nov 14, 2012 3:16 pm
Hi artikal
We have fixed the mistake in the last driver vesion!(V1.0.6.2 URL http://www.tbsdtv.com/download/) and the TS capture driver dont need driver, it was included in the 8920 driver. after install the 8920 driver, the TS capture can woke well!
your said :"n dvbdream says : no signal !" ? Can you put the promble described in more detail?? For example ,the DVBDream setting? frequcy? It is best to have screenshots!!
Thanks !
Best regards!!
smile
Postby artikal » Thu Nov 15, 2012 6:05 am
Tnx Smile <3
Solved
artikal
