signal problim-FastSatFinder
Postby cyberit » Thu Feb 17, 2011 5:16 am
hi
I have bought a 8920 card yesterday... I already had a skystar2 2.6d card.
when i want set dish with 8920... signal is Zero...but my skystars shows 30-40 signal!
i use FastSat Finder 2.7 to setup Dish...this program isnt Compatible with 8920
8920 did not used to adjust the dish?
I guess 8920 cant turn on LNB.
Intro :
For setting up dish should I use SkyStar...then... connect dish to 8920 !
i used 1.0.5.4 driver and update to 1.0.5.8 but problem not solved!
i havent any problem with skystar but 8920 Makes me very annoyed :oops:
There are similar fastsatfinder software compatible with 8920 ?
please help me
cyberit
Re: signal problim-FastSatFinder
Postby steven » Sat Feb 19, 2011 9:53 am
Sorry about this ,because 8920 is designed for stable or smooth signal.So 8920 is not good use to sat finder. :)
Postby cody » Sun Feb 20, 2011 9:40 pm
hi, i'm not sure if TBS 8920 is compatible with FastSat Finder 2.7 or not, but in case you can receive the signal with your other DVB card and then switch the same cable from the dish to TBS 8920 and there is no signal i think the problem has to be somewhere else and not in the dish adjustment. so, please, give us more details about it - you can't receive any transponder with your TBS 8920 card or just some of the transponders?
thanks,
Postby PeterP » Tue Mar 01, 2011 5:37 pm
for what its worth on win7 fastsatfinder is working fine for me.
PeterP
Postby dubaisatshop » Tue Mar 08, 2011 7:04 am
cyberit Wrote:hi
TBS8920 is definitely compatible with Fastsatfinder , make sure you select the appropriate device in device menu.
dubaisatshop
