Blue screen after resuming from standby
Postby DjNDB » Tue Nov 29, 2011 5:30 pm
I've been using the TBS 5922 for a week now, and i've gotten 2 Blue screens since then, both after resuming from standby.
When the first one happened i was using the Driver "TBS 5922 USB DVBS/S2 BDA, 09.09.2011, 2.0.1.6"
I was looking for a solution, and hoped that the recently released Driver "TBS 5922 USB DVBS/S2 BDA, 25.11.2011, 2.0.1.9" would fix it. Today i got another blue screen running the new driver though.
Also, while rebooting directly after the blue screen the system would hang in BIOS POST, even after a cold restart, until i unplug the TBS5922 from USB. It seems like the TBS5922 switches into a state blocking the USB during the crashes. After windows reboot the TBS5922 doesn't work if i just replug USB. It is shown as unknown USB device. I have to unplug the TBS5922 power cable once to make it work again, so the hardware seems to run into a strange locked up state.
The TBS5922 is directly connected to my Mainboards IO-Panel (Model GA-MA78GM-S2H rev 1.1).
I am running Windows 7 64-Bit.
I hope my information helps in debugging the issue. I added the WinDbg output of both bluescreens below.
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Andy\Desktop\TBS Debug\112611-12916-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff800`00ba2730?
Symbol search path is: SRV*c:\websymbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Machine Name:
Kernel base = 0xfffff800`03019000 PsLoadedModuleList = 0xfffff800`0325e670
Debug session time: Sat Nov 26 16:04:26.786 2011 (UTC + 1:00)
System Uptime: 4 days 5:36:51.224
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 9F, {3, fffffa800b0ce440, fffff80000ba2748, fffffa8009026790}
Probably caused by : usbhub.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa800b0ce440, Physical Device Object of the stack
Arg3: fffff80000ba2748, Functional Device Object of the stack
Arg4: fffffa8009026790, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
IMAGE_NAME: usbhub.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4d8c0c15
MODULE_NAME: usbhub
FAULTING_MODULE: fffff880064aa000 usbhub
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x9F
PROCESS_NAME: plugin-contain
CURRENT_IRQL: 2
STACK_TEXT:
fffff800`00ba26f8 fffff800`03103cd2 : 00000000`0000009f 00000000`00000003 fffffa80`0b0ce440 fffff800`00ba2748 : nt!KeBugCheckEx
fffff800`00ba2700 fffff800`030a15fc : fffff800`00ba2830 fffff800`00ba2830 00000000`00000000 00000000`00000001 : nt! ?? ::FNODOBFM::`string'+0x34a90
fffff800`00ba27a0 fffff800`030a1496 : fffff800`03240f00 00000000`0165cec7 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x6c
fffff800`00ba2810 fffff800`030a137e : 00000353`b87b2375 fffff800`00ba2e88 00000000`0165cec7 fffff800`0320fb68 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00ba2e60 fffff800`030a1167 : fffffa80`079431c1 fffffa80`0165cec7 00000000`00000000 00000000`000000c7 : nt!KiTimerExpiration+0x1be
fffff800`00ba2f00 fffff800`03098765 : 00000000`00000000 fffffa80`0b0db2d0 00000000`00000000 fffff880`014cfa00 : nt!KiRetireDpcList+0x277
fffff800`00ba2fb0 fffff800`0309857c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KyRetireDpcList+0x5
fffff880`029f5be0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchInterruptContinue
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0x9F_3_tbs5922_IMAGE_usbhub.sys
Loading Dump File [C:\Users\Andy\Desktop\TBS Debug\112911-12994-01.dmp]
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff800`00b9c500?
Machine Name:
Kernel base = 0xfffff800`03013000 PsLoadedModuleList = 0xfffff800`03258670
Debug session time: Tue Nov 29 09:35:26.705 2011 (UTC + 1:00)
System Uptime: 0 days 20:50:51.365
BugCheck 9F, {3, fffffa80080e9060, fffff80000b9c518, fffffa8015e67890}
0: kd> !analyze -v
Arguments:
Arg2: fffffa80080e9060, Physical Device Object of the stack
Arg3: fffff80000b9c518, Functional Device Object of the stack
Arg4: fffffa8015e67890, The blocked IRP
Debugging Details:
MODULE_NAME: usbhub
FAULTING_MODULE: fffff88006227000 usbhub
BUGCHECK_STR: 0x9F
PROCESS_NAME: System
CURRENT_IRQL: 2
STACK_TEXT:
fffff800`00b9c4c8 fffff800`030fdcd2 : 00000000`0000009f 00000000`00000003 fffffa80`080e9060 fffff800`00b9c518 : nt!KeBugCheckEx
fffff800`00b9c4d0 fffff800`0309b5fc : fffff800`00b9c600 fffff800`00b9c600 00000000`00000000 00000000`00000001 : nt! ?? ::FNODOBFM::`string'+0x34a90
fffff800`00b9c570 fffff800`0309b496 : fffff800`0323af00 00000000`004968ca 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x6c
fffff800`00b9c5e0 fffff800`0309b37e : 000000ae`be197956 fffff800`00b9cc58 00000000`004968ca fffff800`03209bc8 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9cc30 fffff800`0309b167 : 00000033`6c42d3c1 00000033`004968ca 00000033`6c42d3b5 00000000`000000ca : nt!KiTimerExpiration+0x1be
fffff800`00b9ccd0 fffff800`0308796a : fffff800`03205e80 fffff800`03213cc0 00000000`00000000 fffff880`016f0a00 : nt!KiRetireDpcList+0x277
fffff800`00b9cd80 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cd40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
DjNDB
Re: Blue screen after resuming from standby
Postby DjNDB » Wed Nov 30, 2011 9:49 pm
I had 2 more Blue screens like these today. I've just installed Driver V2.0.2.0. I'll see if that changes anything.
DjNDB
Postby jw300 » Fri Jan 06, 2012 6:45 am
Exactly the same as QBox II problem:
viewtopic.php?f=13&t=140&start=20
Try emailing support.
jw300
Postby steven » Tue Jan 10, 2012 11:17 am
Sorry for this problem.
We are solving this problem now,maybe some mainboard have compatible problem,Please just wait our progress news and
notice your mainboard BIOS update news too,update BIOS and try again.
Postby faniemeiring » Sat Feb 25, 2012 12:39 am
Any update on this issue? My TBS5922 shows up as an "unknown device" after restart and I've also had a few blue screens...
On windows 7 23bit
faniemeiring
Postby andysaed » Sun Feb 26, 2012 2:05 am
i have this problem too.
my mainboard:
manufacture:fujitsu
model:fjnb209
chipsetLintel
andysaed
Postby faniemeiring » Mon Feb 27, 2012 12:30 am
andysaed Wrote:i have this problem too.
my mainboard:
manufacture:fujitsu
model:fjnb209
chipsetLintel
Hi Andy,
I hope they fix this soon. Have you had any luck to fix it.
In case it helps this is the procedure I have to follow to get it working again...
1) After startup when it recognises it as unknown USB device..
2) then in device manager uninstall this unknown device
3) then install the drivers (again)...
4) Then unplug POWER from sat tuner (not usb cable) and
5) when you plug back in the power it picks it up correctly....
anyone with any more permanent fixes please help us out ;-)
Anyone from TBS can you please look at this issue and update us on any help and or progress. Thx.
faniemeiring
Postby steven » Wed Feb 29, 2012 2:11 pm
Hi All
When the BSOD happen,Would you mind giving us more detail information.
1. Do you have used USB 3.0 ?
2. Do you have used USB hub?
3. Do you have used other USB device with TBS5922?
Postby andysaed » Thu Mar 01, 2012 3:28 am
hi all
i had been created a topic and explaned my problem.that is more coplex than just a blue screen error
i checked all procedures. everytime a new version comes to on the site
it proves me that the problem is the software not the hardware.
..i have no any bluescreens now...or so few times!(1/1000)
but...when im running..tbs ip data...for satlite internet..or watching tvs....(almostely on tbs ip using)
my windows( 7 os) hangs up.after 2 or 5 minutes that i cant reset my notebook...and forces me to power it off by pluging off.both of the mouse and keyboard dos not work and make me to plugg of
im realy so bored abour this problem...pleeeeeeeeeeeeeeeeeeeees
andysaed
Postby smile » Fri Mar 02, 2012 9:26 am
Hi all
The 5922 driver has been updated to 2.0.2.5.please try to use the new driver. link http://www.tbsdtv.com/download/.
thanks
smile
