problem in first day !!
Postby vahid67 » Sun Feb 13, 2011 6:16 am
hi i bought a QBOX 6920 yesterday and when i connect it to PC for first time it installed good but when i restart the computer or shutdown it , windows cannot recognize it i change windows several times , tried new driver , change slot .... help me please ...
vahid67
Re: problem in first day !!
Postby steven » Sun Feb 13, 2011 9:25 am
Sorry for this,would mind to tell me what's your mainboard, power and other pc config.
and you can get support at support@tbsdtv.com
Postby vahid67 » Sun Feb 13, 2011 2:28 pm
steven Wrote:Hi,
hi,
MB : Biostar TP43D2A7
CPU : Intel Core2Quad 8200
RAM : 2GB
Power : SilverStone 430watt
vahid67
Postby vahid67 » Sun Feb 13, 2011 10:37 pm
my problem in windows XP solved when i update mainboard bios but in windows 7 my system after restart cannot recognize DVB card...
vahid67
Postby cody » Mon Feb 14, 2011 3:44 am
vahid67 Wrote:my problem in windows XP solved when i update mainboard bios but in windows 7 my system after restart cannot recognize DVB card...
all points to hardware incompatibility with your motherboard, including the fact that BIOS upgrade helped for WinXP. so, you can try your 6920 card in other motherboard and i'm quite sure it will work. unfortunately, we can't do much about it and you should ask your motherboard manufacturer for technical assistance and help - they should be able to tell you why PCI-Express slot on their motherboard is not functioning in such unexpected way.
Postby vahid67 » Mon Feb 14, 2011 5:29 am
yeahhhhhhhhhhhh its work on another MB and it's good ....
i must tell this problem to Biostar support
thank you
vahid67
Postby cody » Mon Feb 14, 2011 6:50 am
vahid67 Wrote:yeahhhhhhhhhhhh its work on another MB and it's good ....
it was expected ...
vahid67 Wrote:i must tell this problem to Biostar support
yes, it's not something usual and 6920 works on any other motherboard and so it has to be something on the Biostar motherboard that triggers the problem - their support probably can suggest something. in any case we're here if we can help with something more, e.g. based on what Biostar support suggested.
