Customize Remote Control
Postby eichbaum » Sat Feb 12, 2011 4:16 am
I am using the TBS 6981 with Mediaportal, which works quite well. However I am having some issue with using the remote control. While I am able to map most keys via the Mediaportal Configurator to the desired actions, there are some keys were this is not really possible, like:
- Power => which starts Windows Media Center, but i would like to suspend the HTPC with that button
- Exit => Which seems to send Alt-F4, but I would like to make another assignment.
So my question would be: is there a way to change the key mapping of the TBS remote control?
Thanks in advance
eichbaum
Re: Customize Remote Control
Postby steven » Sat Feb 12, 2011 9:58 am
Our New Card which is use NXP7160 chip have a small remote soft which can customize remote control.
And the older card if you want to customize remote control,you can see the driver folder to edit this file tbs6981vhid.inf
take number key 1 for example
;IR_Virtualcode_*: application shortcut key
; 0x00x x x x xx
; |->ctrl key pressed flag
; |->shift key pressed flag
; |->Alt key pressed flag
; |->keyboard(1 for keyboard, 2 for system key)
; |->Virtualcode(refer to the USB HID usage table)
HKR,"DriverData","IR_Scancode_6", 0x00010001, 0x87
;KEYBOARD_1
HKR,"DriverData","IR_Virtualcode_6", 0x00010001, 0x00011E, 0x00
so number 1 key is 1E if you want to set to another key you can modify it to another value.
You can get the remote key value at http://hotfile.com/dl/103851137/66a5244/RemoteKey.pdf.html
after modified it you should reinstall the VHID Driver!
Postby eichbaum » Sat Feb 12, 2011 9:15 pm
thanks for the quick reply. I could change the key mapping via the inf file. After uninstalling the driver I also had to delete the TBS folder from
C:\Windows\System32\DriverStore\FileRepository
otherwise it was taking the INF file from there.
Another question regarding the remote: Is it possible for the Card to wake up the PC from S3 upon pressing a button on the remote?
eichbaum
Postby cody » Mon Feb 14, 2011 6:39 am
eichbaum Wrote:Another question regarding the remote: Is it possible for the Card to wake up the PC from S3 upon pressing a button on the remote?
even if i didn't look at it, but i don't think so, because supporting wake up from S3 is very specific and i only some WMC-grade remote control kits can do it.
Postby hypernics » Wed Jun 08, 2011 5:20 am
2 keys are missing from the current driver. (TBS6981Driver_V2.0.0.18.rar)
"MODE" key IR Scancode 0x9B
"EPG" key IR Scancode 0x9C
hypernics
Postby steven » Thu Jun 09, 2011 12:55 pm
hypernics Wrote:2 keys are missing from the current driver. (TBS6981Driver_V2.0.0.18.rar)
yes we do not config this 2 keys ,but if you want you can config it by yourself the function you want.
Postby maziv » Thu Sep 22, 2011 2:13 pm
HI steven...
WHERE WE CAN DOWNLOAD THAT APP (TBS VHID PRO).DOES IT WORKS WITH QBOX3 USB?
THANKS PAL
maziv
Postby steven » Thu Sep 22, 2011 4:24 pm
maziv Wrote:HI steven...
THANKS PAL
Hi maziv
I am sorry QBOX3 USB can not use TBS VHID.
