6928 and 6925(Solved)
Postby emesix » Mon Nov 21, 2011 7:31 am
Hi there
I have a little problem with mine setup.
I have a 6928 and 6925. and when i enter them both in mine system.
I dont get data from the 6928 card. When i remove the 6925 all is fine.
Anybody got this also ?
Vincent
emesix
Re: 6928 and 6925
Postby smile » Wed Nov 23, 2011 12:22 pm
Hi emesix
I just have a test,one with TBSViewer ,another with DVB Dream ,but it did not occur you said status.all can work normally! what is the player you use!
smile
Re: 6928 and 6925
Postby emesix » Fri Dec 02, 2011 3:47 pm
Ho there
Sorry for the delayed response.
I use Windows7 x64
and i have this problem with:
ProgDVB 6.80
DVBdream 1.17a
TBSviewer
Windows Media Center
It works with the TBS6928-Blind scan and with linux i get results also.
Its only the 6928 thats in trouble and only if both cards are in the system.
Removale of the 6925 wil make the 6928 work normaly.
For a example i will add a DVBdream scan. as you can see i get good reception but no channel info.
(sorry for the dutch words)
Bezig met zoeken... 10729 V 22000 8PSK 2/3 ... 92%
Geen kanalen gevonden!
Bezig met zoeken... 10743 H 22000 ... -
Geen signaal
Bezig met zoeken... 10773 H 22000 8PSK 3/4 ... 92%
Bezig met zoeken... 10788 V 22000 ... 91%
Bezig met zoeken... 10817 V 22000 8PSK 2/3 ... 93%
Bezig met zoeken... 10832 H 22000 8PSK 2/3 ... 92%
Bezig met zoeken... 10847 V 22000 ... 91%
Bezig met zoeken... 10861 H 22000 ... 92%
Bezig met zoeken... 10876 V 22000 ... 92%
Bezig met zoeken... 10920 H 22000 ... 93%
Bezig met zoeken... 10935 V 22000 8PSK 2/3 ... 92%
Bezig met zoeken... 10979 V 22000 ... 92%
Bezig met zoeken... 11023 H 22000 ... 93%
Bezig met zoeken... 11038 V 22000 ... 92%
Bezig met zoeken... 11097 V 22000 ... 92%
Bezig met zoeken... 11126 V 22000 8PSK 2/3 ... 92%
Bezig met zoeken... 11156 V 22000 ... 92%
Bezig met zoeken... 11170 H 22000 8PSK 2/3 ... 92%
Bezig met zoeken... 11243 H 22000 ... 92%
Bezig met zoeken... 11302 H 22000 8PSK 2/3 ... 92%
Bezig met zoeken... 11317 V 22000 ... 92%
Bezig met zoeken... 11361 H 22000 8PSK 2/3 ... 92%
Bezig met zoeken... 11435 V 22000 8PSK 2/3 ... 92%
Bezig met zoeken... 11464 H 22000 8PSK 2/3 ... 92%
Bezig met zoeken... 11479 V 22000 ... 92%
Bezig met zoeken... 11508 V 22000 ... 92%
Bezig met zoeken... 11538 V 22000 ... 92%
Bezig met zoeken... 11567 V 22000 ... -
Geen signaal
Bezig met zoeken... 11597 V 22000 ... 92%
Bezig met zoeken... 11626 V 22000 ... 91%
Bezig met zoeken... 11670 H 22000 8PSK 2/3 ... 92%
Bezig met zoeken... 11685 V 22000 ... 91%
Bezig met zoeken... 11719 H 27500 ... 92%
Bezig met zoeken... 11739 V 27500 ... 92%
Bezig met zoeken... 11758 H 27500 ... 93%
Bezig met zoeken... 11778 V 27500 ... 92%
Bezig met zoeken... 11797 H 27500 ... 92%
Bezig met zoeken... 11817 V 27500 ... 92%
Bezig met zoeken... 11836 H 27500 ... 92%
Bezig met zoeken... 11856 V 27500 ... 93%
Bezig met zoeken... 11875 H 27500 8PSK Auto ... 93%
Bezig met zoeken... 11895 V 27500 ... 93%
Bezig met zoeken... 11914 H 27500 8PSK Auto ... 93%
Bezig met zoeken... 11934 V 27500 ... 92%
Bezig met zoeken... 11953 H 27500 ... 93%
Bezig met zoeken... 11973 V 27500 ... 91%
Bezig met zoeken... 11992 H 27500 8PSK Auto ... 92%
Bezig met zoeken... 12012 V 27500 8PSK 2/3 ... 92%
Bezig met zoeken... 12031 H 27500 ... 92%
Bezig met zoeken... 12051 V 27500 ... 92%
Bezig met zoeken... 12070 H 27500 ... 92%
Bezig met zoeken... 12090 V 27500 ... 91%
Bezig met zoeken... 12109 H 27500 ... 92%
Bezig met zoeken... 12129 V 27500 ... 91%
Bezig met zoeken... 12148 H 27500 ... 92%
Bezig met zoeken... 12168 V 27500 8PSK 2/3 ... 91%
Bezig met zoeken... 12187 H 27500 ... 92%
Bezig met zoeken... 12207 V 27500 8PSK 2/3 ... 92%
Bezig met zoeken... 12226 H 27500 ... 92%
Bezig met zoeken... 12246 V 27500 ... 91%
Bezig met zoeken... 12265 H 27500 ... 91%
Bezig met zoeken... 12285 V 27500 ... 92%
Bezig met zoeken... 12304 H 27500 8PSK Auto ... 92%
Bezig met zoeken... 12324 V 27500 ... -
Geen signaal
Bezig met zoeken... 12343 H 27500 ... -
Geen signaal
Bezig met zoeken... 12363 V 27500 ... 92%
Bezig met zoeken... 12382 H 27500 8PSK Auto ... -
Geen signaal
Bezig met zoeken... 12402 V 27500 ... 90%
Bezig met zoeken... 12421 H 27500 ... 92%
Bezig met zoeken... 12441 V 29700 8PSK 2/3 ... 91%
Bezig met zoeken... 12460 H 27500 ... 91%
Bezig met zoeken... 12480 V 27500 ... 90%
Bezig met zoeken... 12515 H 22000 ... 91%
Bezig met zoeken... 12522 V 22000 ... 90%
Bezig met zoeken... 12544 H 22000 ... -
Geen signaal
Bezig met zoeken... 12551 V 22000 ... 92%
Bezig met zoeken... 12574 H 22000 8PSK 2/3 ... 91%
Bezig met zoeken... 12581 V 22000 ... 91%
Bezig met zoeken... 12603 H 22000 ... 89%
Bezig met zoeken... 12610 V 22000 ... 90%
Bezig met zoeken... 12633 H 22000 ... 92%
Bezig met zoeken... 12640 V 22000 ... 88%
Bezig met zoeken... 12662 H 22000 ... 91%
Bezig met zoeken... 12669 V 22000 8PSK 2/3 ... 88%
Bezig met zoeken... 12692 H 22000 ... 93%
Bezig met zoeken... 12699 V 22000 ... 92%
Bezig met zoeken... 12721 H 22000 ... 92%
Bezig met zoeken... 12728 V 22000 ... 93%
TP's zonder signaal: 6
Empty: 82
Nameless: 0
Verstreken tijd: 15:08
Video kanalen: 0
Radio kanalen: 0
Datakanalen: 0
Totaal: 0
Klaar met zoeken.
emesix
Re: 6928 and 6925
Postby smile » Fri Dec 02, 2011 4:10 pm
Hi emesix
The TBS6928 driver has been updatad. This is download link http://www.tbsdtv.com/english/Download.html ,then test it again.
thanks
smile
Re: 6928 and 6925
Postby emesix » Fri Dec 02, 2011 4:19 pm
This is a fresh install of windows7.
And i used the drivers on the site.
1.0.0.8 for the 6928 and the 1.0.1.11 for the 6925
TBS driver info
emesix
Re: 6928 and 6925
Postby steven » Sun Apr 15, 2012 8:21 pm
Hi emesix
Sorry for the delay reply.
We are always find what the problem is.Now we have found what is the problem.
Next week we will release the new driver which can solve your problem. :)
Re: 6928 and 6925(Solved)
Postby steven » Tue Apr 17, 2012 9:29 am
We have updated TBS6928 and TBS6925's driver you can download it
on our download page.
