Card preventing BIOS boot?
Postby ian » Sat Jan 29, 2011 6:14 am
I'm having a promblem with this card, hopefully people may have some suggestions to fix it.
The card is in my machine, which runs Win 7 64-bit. I had installed it OK after a few attempts and it was running fine with Windows Media Center.
Unfortunately it is now preventing my system from booting while in the PCI slot. I turn the machine on and it will just be on, not loading up, unless I take the card out. Not sure what might fix this problem or if it means there is a problem with the Tuner Card or PC?
Any tips appreciated.
Ian
ian
Re: Card preventing BIOS boot?
Postby cody » Tue Feb 01, 2011 7:30 am
hello Ian,
please, try to test the card in another computer - there is no other way to rule out of it's problem with your computer or your TBS 8920 card hardware got faulty and causes the troubles.
thanks,
