Signal strength/quality
Re: Signal strength/quality
Postby bigman » Thu Nov 17, 2011 9:28 am
Hi bl4ck
Maybe you have high quality singal :D ,so it always keep the strengh and quality in 90% and 99%, but we will go to test the card.
thank you for you view :D .
bigman
Postby Mohammad » Wed Nov 23, 2011 4:00 pm
Hi...
where is driver v1.0.0.6 ???
in download section latest driver for tbs 6922 is v1.0.0.5 ??
if its available please share it.
i have many problem whith signal & strength in driver v1.0.0.5.
quality is 20% Weaker than my other tbs dvb card (8920 whith latest driver).
Mohammad
Postby steven » Wed Nov 23, 2011 5:04 pm
Mohammad Wrote:Hi...
Hi Mohammad
Would you mind try this new driver V1.0.0.8,
here is the download link:
http://hotfile.com/dl/135782290/f8d0833 ... r.rar.html
and can you send your test report here
Postby Mohammad » Wed Nov 23, 2011 10:25 pm
i download & test this stregth level is now 95% at all & quality that with previus driver Was 65~70% is now 80%.
signal & quality level is more stable with new driver.
but in some satellites for example : intelsat 902
11136 & 11161 ( Data Freq) = 0 quality 60% signal
11555 = 75~85 quality & 95% signal
tbs 6922 with this driver cant get some frequency
for now 1.0.0.8 is better than previus version.
tnx.
Mohammad
Postby steven » Fri Nov 25, 2011 9:33 am
Mohammad Wrote:i download & test this stregth level is now 95% at all & quality that with previus driver Was 65~70% is now 80%.
tnx.
Hi Mohammad
Is these frequency can be locked with the older driver?and can you tell us the exact frequency and sat.
Postby Mohammad » Fri Nov 25, 2011 7:28 pm
Hi mr steven.
No with driver 1.0.0.5 & 1.0.0.8 & now with 1.0.0.9 this two freq haven't quality.
satellite : 62.E Intelsat 902
freq : 11136 v 30000 DVB-S = with all driver that hase been released quality is 0%
freq : 11161 v 5166 DVB-S2 8PSK = with all driver that hase been released quality is 0%
Mohammad
Postby steven » Sat Nov 26, 2011 11:13 am
Mohammad Wrote:Hi mr steven.
Hi Mohammad
Is this two freq is always 0 or sometimes is 0,and what about the older driver?
is it 0 too?
and about 1.0.0.9 would you mind test like this,first use the normal TP which have quality is not 0,then change to
this two freq to see whether the quality is 0%,then change to normal again,
To see if it is ok.
Postby Mohammad » Sat Nov 26, 2011 5:16 pm
Hi.
with all drivers always quality is 0.
when i switch from normal TP for example : 11555 v 27500 quality is 80~85% - i switch from with TP to 11136 v 30000 but always this freq havent quality.
problem with skynet in version 1.0.0.9 is now solved.
with previus driver skynet won't work for me.but with this new version working fine.
testing more...
Mohammad
Postby steven » Mon Nov 28, 2011 3:32 pm
Mohammad Wrote:Hi.
testing more...
Hi Mohammad
Thanks for your test report.we will have more test too.
