TBS-5922 Mythtv (ubuntu 11.10) No frontend [SOLVED]
Postby zeuf69 » Sun Nov 13, 2011 4:51 pm
I ve been compiling the drivers and installing with these steps :
sudo -s
apt-get update
apt-get install build-essential
apt-get install linux-headers-`uname -r`
apt-get install linux-kernel-devel
mkdir /root/tbs && cd /root/tbs
wget http://www.tbsdtv.com/download/common/linux-tbs-drivers_111103.zip
unzip linux-tbs-drivers_111103.zip
sudo sudo mv dvb-fe-cx24116.fw /lib/firmware/
sudo sudo mv dvb-usb-tbsqbox-id5922.fw /lib/firmware/
sudo sudo mv v4l-cx23885-avcore-01.fw /lib/firmware/
cd linux-tbs-drivers
sudo v4l/tbs-x86.sh
make
make install
After rebooting, it's seems that i cant get the TBS5922 to work.
dmesg | grep dvb
[   18.328068] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in cold state, will try to load a firmware
[   18.402817] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5922.fw'
[   18.594102] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in warm state.
[   18.594333] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[   18.594403] dvb-usb: MAC address reading failed.
[   19.064043] dvb-usb: no frontend was attached by 'TBS QBOX22 DVBS2 USB2.0'
[   19.065438] dvb-usb: schedule remote query interval to 150 msecs.
[   19.065450] dvb-usb: TBS QBOX22 DVBS2 USB2.0 successfully initialized and connected.
[   19.096617] dvb-usb: TBS QBOX22 DVBS2 USB2.0 successfully deinitialized and disconnected.
[   20.373412] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in cold state, will try to load a firmware
[   20.397896] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5922.fw'
[   20.536034] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in warm state.
[   20.536149] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[   20.641752] dvb-usb: MAC address: 00:22:ab:c0:1e:a0
[   20.968257] Modules linked in: snd_hda_codec_realtek tbs5922fe(P) ir_lirc_codec lirc_dev ir_mce_kbd_decoder ir_sony_decoder ir_jvc_decoder ir_rc6_decoder ir_rc5_decoder dvb_usb_tbsqbox22 dvb_usb ir_nec_decoder dvb_core rc_core joydev usbhid hid nvidia(P) arc4 snd_seq_midi snd_rawmidi snd_hda_intel(+) psmouse snd_hda_codec snd_hwdep serio_raw snd_seq_midi_event ath9k snd_pcm snd_seq mac80211 ath9k_common ath9k_hw ath snd_timer cfg80211 snd_seq_device snd soundcore snd_page_alloc lp parport ahci libahci r8169
[   20.968442]  [<f81b1372>] tbsqbox22_frontend_attach+0x32/0x180 [dvb_usb_tbsqbox22]
[   20.968454]  [<f81aa7b7>] dvb_usb_adapter_frontend_init+0xc7/0x170 [dvb_usb]
[   20.968465]  [<f81aa5dc>] ? dvb_usb_adapter_dvb_init+0x10c/0x1a0 [dvb_usb]
[   20.968475]  [<f81a9952>] dvb_usb_device_init+0x372/0x6d0 [dvb_usb]
[   20.968499]  [<f81b1039>] tbsqbox22_probe+0x29/0x40 [dvb_usb_tbsqbox22]
sudo ls -l /dev/dvb/adapter0
total 0
crw------- 1 root root 212, 0 Nov 13 09:24 demux0
crw------- 1 root root 212, 1 Nov 13 09:24 dvr0
crw------- 1 root root 212, 2 Nov 13 09:24 net0
It seems i have no frontend.
How can this be ??
zeuf69
Re: TBS-5922 Mythtv (ubuntu 11.10) No frontend
Postby p3r0n » Mon Nov 14, 2011 11:48 pm
zeuf69 Wrote:Hello,
total 0
How can this be ??
I had the same problem, but a tried a second time to install the driver... you can too and maybe it result good.
Bye
p3r0n
Postby zeuf69 » Tue Nov 15, 2011 12:35 am
Thank you. I ve tryed 3 times and still the same.
I have got 3 WARNINGS when i MAKE
WARNING I
cd <your kernel dir>
./scripts/make_myconfig.pl
make[1]: Leaving directory `/tmp/tbs/linux-tbs-drivers/v4l'
make[1]: Entering directory `/tmp/tbs/linux-tbs-drivers/v4l'
perl scripts/make_config_compat.pl /lib/modules/3.0.0-13-generic/build ./.myconfig ./config-compat.h
creating symbolic links...
WARNING II:
CC [M]  /tmp/tbs/linux-tbs-drivers/v4l/dvb_ca_en50221.o
In file included from /usr/src/linux-headers-3.0.0-13-generic/arch/x86/include/asm/uaccess.h:570:0,
                 from include/linux/poll.h:14,
                 from /tmp/tbs/linux-tbs-drivers/v4l/dvbdev.h:27,
                 from /tmp/tbs/linux-tbs-drivers/v4l/dvb_ca_en50221.h:27,
                 from /tmp/tbs/linux-tbs-drivers/v4l/dvb_ca_en50221.c:41:
In function 'copy_from_user',
    inlined from 'dvb_ca_en50221_io_write' at /tmp/tbs/linux-tbs-drivers/v4l/dvb_ca_en50221.c:1314:26:
/usr/src/linux-headers-3.0.0-13-generic/arch/x86/include/asm/uaccess_32.h:211:26: warning: call to 'copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct [enabled by default]
  CC [M]  /tmp/tbs/linux-tbs-drivers/v4l/dvb_frontend.o
WARNING III
Building modules, stage 2.
  MODPOST 506 modules
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs8921ctrl.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs8921ctrl.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs5922ctrl.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs5922ctrl.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs5921ctrl.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs5921ctrl.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbsctrl.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbsctrl.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs5921fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs5921fe_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs5922fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs5922fe_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs62x0fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs62x0fe_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs6921fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs6921fe_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs6922fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs6922fe_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs6925ctrl_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs6925ctrl_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs6928fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs6928fe_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs6980fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs6980fe_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs6981fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs6981fe_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs6984fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs6984fe_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs6992_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs6992_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs8921fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs8921fe_driver.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs8922fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs8922fe_driver.o
  CC      /tmp/tbs/linux-tbs-drivers/v4l/adp1653.mod.o
  LD [M]  /tmp/tbs/linux-tbs-drivers/v4l/adp1653.ko
  CC      /tmp/tbs/linux-tbs-drivers/v4l/adv7170.mod.o
Any idea ??
zeuf69
Postby zeuf69 » Tue Nov 15, 2011 12:49 am
the command :
return that package does not exist.
Is it the same for you ??
zeuf69
Postby zeuf69 » Tue Nov 15, 2011 12:58 am
This is the 5th time i rebuild and re-install the drivers but no way.
I still have no frontend at all:
zeuf69@box:/tmp/tbs$ szap-s2 -a 0 -c astra_szap-s2.conf -p -r -S 0 "BBC"
reading channels from file 'astra_szap-s2.conf'
zapping to 3 'BBC':
sat 0, frequency 11597 MHz V, symbolrate 22000000, coderate auto, rolloff 0.35
vpid 0x00a3, apid 0x005c, sid 0x2742
opening frontend failed: No such file or directory
zeuf69
Postby SergioDanielG » Tue Nov 15, 2011 3:42 am
zeuf69 Wrote:WARNING III
MODPOST 506 modules
Any idea ??
This is the "warning" can help to find the solution. It's a driver problem.
Best regards
SergioDanielG
Postby zeuf69 » Tue Nov 15, 2011 4:16 am
Ok, thank you. I ve been contacting support and still no answer.
Why am i having problems if some other people with the same Ubuntu 11.10 and the same version of driver do not get this problem ?
I tryed on 2 different machines (one classi ubuntu 11.10, one Mythtv 11.10) and i still have the same troubles.
If anyone can help.
Thanx
zeuf69
Postby p3r0n » Tue Nov 15, 2011 3:24 pm
Today there is a new driver... maybe the solution is that!
Best regard!
p3r0n
Postby zeuf69 » Tue Nov 15, 2011 3:50 pm
I ve done it! Downloading the latest driver :
wget http://www.tbsdtv.com/download/common/linux-tbs-drivers_111115.zip
Still the same WARNING I about kernel sources.
Then WARNING II is :
  CC [M]  /tmp/tbs/linux-tbs-drivers/v4l/dvb_demux.o
  CC [M]  /tmp/tbs/linux-tbs-drivers/v4l/dvb_filter.o
In file included from /usr/src/linux-headers-3.0.0-13-generic-pae/arch/x86/include/asm/uaccess.h:570:0,
/usr/src/linux-headers-3.0.0-13-generic-pae/arch/x86/include/asm/uaccess_32.h:211:26: warning: call to 'copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct [enabled by default]
WARNING III :
LD [M] /tmp/tbs/linux-tbs-drivers/v4l/firedtv.o
LD [M] /tmp/tbs/linux-tbs-drivers/v4l/snd-bt87x.o
MODPOST 508 modules
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs5880ctrl.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs5880ctrl.o
WARNING: could not find /tmp/tbs/linux-tbs-drivers/v4l/.tbs5880fe_driver.o.cmd for /tmp/tbs/linux-tbs-drivers/v4l/tbs5880fe_driver.o
CC /tmp/tbs/linux-tbs-drivers/v4l/dm1105.mod.o
LD [M] /tmp/tbs/linux-tbs-drivers/v4l/dm1105.ko
CC /tmp/tbs/linux-tbs-drivers/v4l/drxd.mod.o
^Cmake[3]: *** Se borra el archivo «/tmp/tbs/linux-tbs-drivers/v4l/drxd.mod.o»
make[3]: *** [/tmp/tbs/linux-tbs-drivers/v4l/drxd.mod.o] Interrupción
make[2]: *** [modules] Interrupt
make[1]: *** [default] Interrupción
make: *** [all] Interrupción
zeuf69
Postby p3r0n » Tue Nov 15, 2011 7:12 pm
zeuf69 Wrote:
sudo v4l/tbs-x86.sh
make
make install
How can this be ??
Maybe it can be wrong... I used
sudo ./v4l/tbs-x86_r3.sh
make
make install
p3r0n
