Driver v2.0.1.1
Driver v2.0.1.1
Postby Daimon » Sun Nov 13, 2011 7:40 am
1. TBS6981 windows driver is updated to v2.0.1.1, which support Unicable under the latest TBSViewer V20111103.
The downloaded file is still version 2.0.0.21
Daimon
Re: Driver v2.0.1.1
Postby Bobthe » Tue Nov 22, 2011 9:32 pm
Noticed this as well - will the correct version be uploaded any time soon?
Cheers
Bob.
Bobthe
Re: Driver v2.0.1.1
Postby warumnix » Wed Nov 23, 2011 8:56 am
it's already the latest version v2.0.1.1
http://www.tbsdtv.com/download/TBS6981/TBS6981Driver_V2.0.1.1.zip
warumnix
Re: Driver v2.0.1.1
Postby Manolito » Wed Nov 23, 2011 2:01 pm
No, unfortunately it's NOT the latest version. Although the file name hints to version 2.0.1.1, the zip archive still contains the old version 2.0.0.21 from August 2011. You can check this by opening the inf file of the driver (tbs6981.inf) in a text editor:
"DriverVer=08/31/2011,2.0.0.21"
Best regards,
-Manuel-
Manolito
Re: Driver v2.0.1.1
Postby steven » Wed Nov 23, 2011 5:19 pm
Manolito Wrote:No, unfortunately it's NOT the latest version. Although the file name hints to version 2.0.1.1, the zip archive still contains the old version 2.0.0.21 from August 2011. You can check this by opening the inf file of the driver (tbs6981.inf) in a text editor:
Best regards,
-Manuel-
Hi Manolito
Sorry this problem,We have update the file on our download page,
and you can download this link too:
http://hotfile.com/dl/135783447/31d64e8 ... 1.zip.html
and would you mind send your unicable test report here?
Re: Driver v2.0.1.1
Postby Manolito » Thu Nov 24, 2011 5:37 pm
Hi Steven,
thank you for your quick response. I downloaded and tested the latest driver yesterday.
I'm not using Unicable and TBSViewer, but DVBLogic TV Source and Windows Media Center on Windows 7 64bit.
The driver seems to work properly, but the time between switching a channel is far too long, in my opinion.
I noticed this lag since driver 2.0.0.19. Driver 2.0.0.20, 2.0.0.21 and the latest 2.0.1.1 were a little faster, but it still takes 8-10 seconds for switching from one HD channel to another. So, I went back to driver 2.0.0.18 which takes 4-6 seconds for channel switching with my configuration.
Best regards,
-Manuel-
Manolito
Re: Driver v2.0.1.1
Postby steven » Sat Nov 26, 2011 11:01 am
Manolito Wrote:Hi Steven,
Best regards,
-Manuel-
Hi Manuel
Thanks for your reply.and about the time.
Let me tell you why,the new driver use more time because if some user whos singnal is not very well,it will take need more time to lock,
if the time is not longer enough,they will miss the lock,so we let it longer,this will let all people work ok.
Wish you can understand this.
Re: Driver v2.0.1.1
Postby onelegend » Sun Nov 27, 2011 6:40 am
I also experience similar channel change times.
This is with dvblogic, 8/10 secs. With dvbviewer, channel change times are fast-half a sec
Isignal strength is very good, 90%.
I have created another thread post FYI.
onelegend
