Transponder Lists
Transponder Lists
Postby mikech » Sat Nov 12, 2011 10:20 pm
I have a Qbox CI and I am sure this is a simple question. I have spent quite a while trying to either update or add an transponder list ini file. These are located in my installation (Vista) under C:\Program Files\TBSViewer\Transponders. They save ok but TBSViewer behaves as if it is reading another set somewhere else as the data in the transponder list in TBSViewer never changes. What have I missed??
Impressed so far with the blind scan.
Mike
mikech
Re: Transponder Lists
Postby mikech » Mon Nov 14, 2011 12:47 am
I have answered my own question. The file it is reading is in \ProgramData\CMUV\TBS Viewer\Transponders. This is copied from the one in the program folder on first startup or again if there are no .ini files in the CMUV folder.
mikech
